X475 PTO Switch and Parking brake
   / X475 PTO Switch and Parking brake #1
x475owner
John Deere X475
My X475 pto switch won't stay on/engaged. I have to hold it up to keep the mower deck running. If I pull on it and twist it a little, it will stay on but the next time I go in reverse (holding the pto switch up) when I go forward most times the switch will not keep the pto engaged.
1- Seems like maybe the pto switch should be replaced?
2- If so, is there a trick to remove it from the dashboard? I can't seem to squeeze the tabs from the under side to pop it out.
3- How do I adjust the parking brake, that seems to take a little jostling around to disengage it, almost like the linkage has to be adjusted or tightened possibly?
Thank you!
Craig
   / X475 PTO Switch and Parking brake #2
I have to spray the mechanism once in a while to keep the parking brake release working. Looking up from below when the mower deck is off works best to see what needs some WD-40 or similar slippery stuff.
   / X475 PTO Switch and Parking brake #3
X474 Welcome to TBN 📣
Richard
Is this what your switch looks like?
Kubota KX91-3S2 Excavator (A44391)
Kubota KX91-3S2...
1986 International S52300 Dump Truck (A44391)
1986 International...
2011 Mercedes-Benz E-Class Passenger Car, VIN # WDDHF8HB8BA502618 (A44391)
2011 Mercedes-Benz...
2013 Ford Explorer AWD SUV (A44572)
2013 Ford Explorer...
2016 Dodge Charger Sedan (A44572)
2016 Dodge Charger...
2017 Ford F-350 Pickup Truck, VIN # 1FT8W3DT7HEF37714 (A44391)
2017 Ford F-350...
