Mtnlover64
- Joined
- May 3, 2012
- Messages
- 49
- Location
- Walsenburg, Colorado
- Tractor
- JD X585,Mitsubishi/sakoh Beaver,ford 195
Pod evening gents, been a little while since I've been on or posted... Time goes by way to quick. I posted a while back about installing a Kwikway loader on a JD x585. I diverted the oil from the pump through the loader valve then back to the original line. Everything works good that way.. A little problem with the power steering sometimes if using the loader and turning. I decided to replace the Kwikway valve with a new valve-it's a two spool with power beyond capability, regeneration ,float and it's a wobble stick. My question is if the stock lines are 1/2 inch, the lines on the loader are 1/2 inch then 1/2 inch lines should be plenty running from the new valve to the quick couplers for the loader right ? I am debating between running steel lines or hoses, any suggestions
