XJ2025H lighting issue
   / XJ2025H lighting issue #1
LandofCheese
WI
LS XJ2025h
First off I want to say hello from WI, long time lurker, I have gotten a lot of info from this site from all you guys/gals over the years. Now Im hoping to get a little more help.
Ok for my question....
Last fall I picked up a gently used XJ2025h for a great price (came with MMM, box blade, rear hyd ports, and rear filled fluid. Guy only sold it cause he was moving from 3 to 40 acres) so far ive only had 2 issues, one the oil dipstick keeps popping out, and two the issue im really posting this thread for is that I have no working turn signals/hazzards. I didnt notice till I had the tractor home.
All other lights work, headlights,running lights of ROPS, dash lights, rear work light all work. The dash responds to the left/right/hazards appropriately. As in it looks like it should be working to the bulbs on the ROPS.
Bulbs are good, all connections appear good (both under dash and socket). I don't know where to go from here, because literally eveything else works and appears like it should be working.
Im looking for pointers on where I can go from here, while im not new to tractors or working on machines and am new to something this new! I just wanna make sure im not missing something super obvious.
Thanks guys,
   / XJ2025H lighting issue #2
Welcome to the forum, man from Cheeseland. :) First on the dipstick. One of our members has a video on that : Keep your dipstick where it belongs... on your LS tractor - YouTube I've had the dipstick come out once, so I put a shoestring bungie from the stick to the frame. I also don't idle below 1100 or so and the shaking some have isn't there for me.
Secondly if you don't have power at the ROPS mounted sockets, this is a quick list from the troubleshooting section.
The fuse block is accessible from the panel behind the ignition switch. 3 knobs and 1 screw for the throttle.
Blown #4 20-amp fuse • Replace 20-amp fuse • Faulty combination light switch• Test switch, replace if necessary • Faulty flasher unit• Test flasher unit, replace if necessary • Hazard light bulbs failure• Replace bulbs as necessary • Improper ground• Check ground location, for clean contact area . Keep us in the loop.
Thank you Tomplum,
I have been avoiding super low idle because of that very reason, and find that as you say anything above 1100rpm is much much smoother, is there a dealer replacement to fix this dipstick issue? and if not its no biggy. I will likely do something like you have done.
I've been very busy lately and haven't been able to look at the tractor lightning issue since I asked my question. I'm hoping to get at it and fix it this weekend. (it's suppose to be near 50!) anything special I should need other than a multi-meter?
   / XJ2025H lighting issue #4
The first 50 degree weekend. A good feeling for sure. It is likely a matter of just getting into it. A multimeter would be a good thing. Don't forget about charcoal for the grill....
it was a GREAT weekend weather wise, now back to cold again but it was a nice sunny break for once, and i did do some grilling haha.
now for my electrical issue. I am stumped....
OK so I went though everything, blew out all the connectors and checked everything. It is good all the way through. All switches and relays are working as they should. I tested the sockets and they are getting 12v, 0v, 12v, 0v just like they should be. Both bulbs looked perfectly OK, but I went to the store anyway and got two new ones and put them in.... still nothing, I rummaged though the garage and found some other bulbs that I know are good. STILL nothing. I check check and re-check that the socket is getting power it is, 12v, 0v, 12v, 0v....... at this point I have no idea what to do.... the bulbs are a B9 base, nothing seems out of place and the socket is getting power as it should.... :mur::pullinghair::mur:
If anyone has any ideas I'm ALL EARS!!!!
   / XJ2025H lighting issue #6
The sockets are getting power but the bulb isn't lighting? Unless the terminals are severely corroded, I don't see how that is even possible...
   / XJ2025H lighting issue #7
I take it you are using a volt meter. Try a test light with a filament. It is possible to have voltage and almost no current. A bad connection can let voltage through but not enough amperage to light a bulb.
*Smacks forehead* yes I am using a volt meter. I'm ashamed to say I totaly flaked on checking the amperage part of the electical equation... I will dig out my test light and report back. Thank you for reminding me to check for amps 3Lfarms!
   / XJ2025H lighting issue #9
Is it possible the bulbs are wrong or installed 180 off? I'm not sure what a B9 base is myself. A ground unhooked somewhere?
Took out the test light. Lights up nice and bright on off on off. And im sorry about the b9 base thing I was mistaken, its a basic auto bulb, 12v 21w. Put the bulbs back in after my test still nothing. To say I am at a loss is an understatement. .... I feel I need a young priest, an old priest, and a whole lot of luck to get this voodoo figured out.
2006 INTERNATIONAL 4300 DT466 SBA 4X2 BUCKET TRUCK (A51406)
2006 INTERNATIONAL...
UNUSED MOWER KING SSB72 BOX BROOM (A51244)
UNUSED MOWER KING...
2024 AGT KFE-20 2,000lb Electric Forklift (A50322)
2024 AGT KFE-20...
66" Skidloader Tooth Bucket (A50774)
66" Skidloader...
2017 John Deere 30G Mini Excavator (A50322)
2017 John Deere...
Wolverine Quick Attach Hydro Slide Pallet Forks (A50514)
Wolverine Quick...
