XT1
   / XT1 #2
Check all your safety switches. I'm always forgetting about these. The seat has one, the brake has one and the blade driver belt handle has one. Make sure you have all of them set up for a normal start.
   / XT1 #3
   / XT1 #4
If you haven't charged your battery, do so or take it and have it load tested. With the key on, the anti-backfire solenoid below the carb should have drained the battery pretty low if it was working. If you were to set the park brake and cycle the key switch from off to on you should be able to hear / feel the solenoid activate and click. Or maybe the PTO is engaged is all.
John Deere 1025R (A53317)
John Deere 1025R...
BELSHE DT-235 (A53843)
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
CUSHMAN HAULER PRO GAS GOLF CART (A51406)
CUSHMAN HAULER PRO...
Landoll Lowboy Trailer (A55315)
Landoll Lowboy...
2008 Isuzu NPR-HD Landscape Dump Truck (A53422)
2008 Isuzu NPR-HD...
