XXth thread on size of disc to use...
   / XXth thread on size of disc to use... #1
npaden
Platinum Member
Lubbock, Texas
2011 LS U5030C
Okay, this has been covered a dozen times and I know there are several rules of thumb on how big of implements to use based on the hp of the tractor. I've heard a lot of 5hp per foot of implement statments for about every implement imaginable.
My specific situation is that I have a 45hp 4wd Kubota tractor and am looking to buy some duplicate implements to be able to leave on my property that is 100 miles away instead of having to haul everything back and forth. The #1 implement I would like to purchase and leave down there is a tandem disc.
I currently have an 8' tandem disc that I use with my tractor and it pulls it easily in 4th gear and will generally pull it in 5th gear but if it digs in really deep it will put some strain on the engine.
Looking for used discs I see a lot of 12' pull type tandem discs but not many 3 point type 8' discs. I talked to a guy selling one of the 12' discs and he said he is pulling it with his 35hp 2wd tractor. Seems like a strech to me. The thing is that these 12' pull type discs are everywhere around here and I could probably pick one up pretty cheaply and maybe even justify spending the money on a rear remote to run the hydraulic on it for not much more than I could pick up a good 8' 3 pt disc.
What do you guys think? If I'm pulling the 8' disc at 4mph in 4th gear and pull a 12' disc at 2mph in 2nd gear it would actually take more time to disc the field with the larger disc. If I can pull it in 3rd gear at 3mph it would take the same amount of time. Am I biting off more than my tractor can reasonable chew with a 12' disc?
I'm going to be working just over 20 acres on the new property. Probably will be planting 16 acres in winter wheat and oats as soon as I can pick up a disc.
   / XXth thread on size of disc to use... #2
From all the old farmer friends they say a pull type will dig better than a 3pt type. Some of the bigger pull type do have adjustments (springs on the tongue) to put more force to the ground so you have some adjustment. But you can also use the wheels to take some weight off the disc if needed.
But again it depends on the soil conditions, sandy loan, hard clay types, etc.
Good Luck,
Rob
2017 Ram 4500 Bucket Truck (A52748)
2017 Ram 4500...
2015 FREIGHTLINER CASCADIA (A52472)
2015 FREIGHTLINER...
6000 GAL FUEL SKID (A52472)
6000 GAL FUEL SKID...
2021 M&J PRESHRED 4000M SHREDDER (A53426)
2021 M&J PRESHRED...
2014 BOMAG BW 213 DH-4 (A52472)
2014 BOMAG BW 213...
2021 DEERE 333G LOT NUMBER 198 (A53084)
2021 DEERE 333G...
