yanmar 1610
   / yanmar 1610 #1
schalfback
Can anyone tell me where to get a oil psi sending unit and exactly where is it located.My oil psi gauge does not work.Also has any body added water to the rear tires for extra traction
thank you A happy owner
   / yanmar 1610 #2
The oil pressure switch is located right beside the oil filter. The 1610 did not have an oil pressure gauge though, only a light. If you have a gauge you will need a different sender but the replacement pressure switch for the factory light is here --
Yanmar Tractor Parts: OIL PRESSURE SENDING SWITCH_
Aaron
Hoye Tractor Parts
(940)592-0181
Contact Us
   / yanmar 1610 #3
hi schalfback, yes I added -20* Windshield Washer Fluid to my tires for ballast. the results of ride and traction were immediately noticed by me as an improvement.
→ water - 8.35 pounds per gallon, rim rust over the long term will be an issue
→ windshield washer fluid - helps prevent rim rust and has a lower freeze point than water
→ antifreeze - helps prevent rim rust and the freeze point can be regulated to meet climatic conditions
→ Calcium Chloride - about 11.5 pounds per gallon, highly corrosive, tubes recommended
→ Rim Guard - about 10.8 pounds per gallon, No rim rust, area availability?
the cost of antifreeze or WWF was very close, i chose WWF because it should be more environmental friendly than the antifreeze, at the time of the inevitable tire puncture.
there are many posts detailing the loading of tires for ballast with allot more detail.
2016 CATERPILLAR 259D SKID STEER (A51242)
2016 CATERPILLAR...
2017 TRAILSTAR END DUMP TRAILER (A50854)
2017 TRAILSTAR END...
2018 CATERPILLAR D6T LGP CRAWLER DOZER (A51242)
2018 CATERPILLAR...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A49461)
2021 Ver-Mac...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
MCELROY COOL PACK 20 (A50854)
MCELROY COOL PACK...
