Yanmar sitting outside in rain, exhaust uncovered!
   / Yanmar sitting outside in rain, exhaust uncovered! #1
pretendfarmer
WA
John Deere 790
I am worried because my tractor is sitting outside in heavy rains, and the exhaust is not covered. I am out of state right now, and cannot get back to it for a week or so. It will ultimately be stored under cover, but the rains came early and heavy. There has been nearly 3 inches of rain. What can I expect has happened from the heavy rain, and what can I do to remedy it once I get back?
   / Yanmar sitting outside in rain, exhaust uncovered! #2
I expect these things get dunked once in a while in the rice paddies - and that is why they have a compression release.
I would remove the exhaust manifold (4 bolts) and pour the water out of the exhaust. (Its gasket is usually re-usable). Then USE THE COMPRESSION RELEASE to spin it and blow any water out of the cylinders, before cranking it under compression - incompressible water can shatter a piston or bend a rod.
Then maybe change the oil if it looks milky.
I doubt you've hurt anything.
The exhaust does have a 90 degree bend at the top, but rain doesn't always come straight down.
2013 MACK PINNACLE CHU613 DAY CAB (A50854)
2013 MACK PINNACLE...
2015 DODGE RAM...
2017 JOHN DEERE  30G (A50854)
2017 JOHN DEERE...
MIDLAND POLY PIPE REEL TRAILER (A50854)
MIDLAND POLY PIPE...
2005 CATERPILLAR 12H MOTOR GRADER (A51406)
2005 CATERPILLAR...
FORD COBRA REPLICA RACING CAR (A51222)
FORD COBRA REPLICA...
