Yanmar tiller on BX-22, will the PTO shaft fit?
   / Yanmar tiller on BX-22, will the PTO shaft fit? #1
Mike_C
Ohio, USA
Kubota BX-22
I'm considering a used 52" yanmar tiller for my bx-22. I've read a lot of posts on here about some attachments needing to have the pto shaft shortened to fit a bx-22, and I have also been told that the pto shaft on the yanmar tillers is too short for some tractors.
It sounds like the right combination, but does anyone know for sure?
P.S. I've read the postings about tillers in the yanmar forum but found nothing conclusive.
   / Yanmar tiller on BX-22, will the PTO shaft fit? #2
I suspect you will need to checkfit it on your machine to know for sure.
For example, I bought a new Bush Hog tiller with my new BX2200. Dealer set it up by cutting the PTO shields/shaft to the proper length.
Then I added Pat's easy change system (a great deal, BTW), but that moved my tiller back about 4" or so. One time I was tilling and the rear wheels went over a mount of dirt, letting the tiller lower even more. The PTO shaft came apart!
I went to a drive line repair shop (for big trucks) and they cut me a chunk of PTO tube about 4" longer than my old one.
I measured the open / closed lengths that would fit, by raising and lowering the 3PH and measuring.
The new tube chunk cost me <$20. (Its about $50 a 4 foot stick at TSC).
So if the PTO coupler fits, I wouldn't be afraid to buy it and make a new length PTO shaft and shields.
You really need to check the measurements though, as you could break/damage parts of the tiller or tractor if the PTO shaft bottoms out.
Ron
I'm going to take my tractor with me to try the tiller for fit. As far as changing the length of the pto shaft, can I assume that because it rotates so slow that perfect balance is not an issue? I mean, if I cut the tube and weld it myself and it's not perfectly aligned tube-to-tube, is that a big deal?
2022 Third Coast Reversible Plate Compactor (A51573)
2022 Third Coast...
2016 KENWORTH T270 S/A SERVICE TRUCK (A51247)
2016 KENWORTH T270...
2018 Big Tex Tandem Equipment Trailer (A52384)
2018 Big Tex...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A53472)
GALAXY - SET OF...
2005 Ford F-750 Crew Cab Heil 5 Yd Dump Truck (A51692)
2005 Ford F-750...
