YFL 155 float valve operation
   / YFL 155 float valve operation #1
Strahwberry
YM155D
Hi all,
I have a question, and I tried my best goggle-fu skills and couldn't find an answer.
As you know, I'm brand new to tractors. This question feels a little obvious.
How do you engage the float function on a YFL 155, with what is probably an original loader valve control?
Thanks!
Jon
   / YFL 155 float valve operation #2
Some valves don't have a float position but, if it does, you just move the lever beyond the normal lower position. Push the lever to lower the bucket and then you would just push it a little more and it should go from 'power down' to a float. Normally there is a detent there to hold the valve in that position. Some valves don't have a float. Some have it only on the lower position. Some also have it on the dump position.
2016 MACK CXU613 MID-ROOF SLEEPER (A58214)
2016 MACK CXU613...
2004 Mack CV713 Granite Fuel and Lube Truck (A59230)
2004 Mack CV713...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Kubota SVL 75-2 (A53317)
Kubota SVL 75-2...
2012 DOOSAN G25 GENERATOR (A58214)
2012 DOOSAN G25...
2007 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A58214)
2007 INTERNATIONAL...
