ym 2000 4x4 front seals
   / ym 2000 4x4 front seals #1
runningbird
Gisela, AZ
yanmar 1110d ,fx28d
need to do the front axle seal on my 2000, did the rear 2wks ago, piece of cake once I got the hubs off. any info would be apprciated.
thanks
Mark
   / ym 2000 4x4 front seals #2
If you did the rears already - the front will be no problem. You can see how they come apart here-->
4WD_EXTERNAL: Yanmar Tractor Parts
Just remove the wheel and the 4 bolts (#52) that hold on the steering arm and the box halves will seperate. This will let you move the project to a workbench. From there you can replace the knuckle seal (#31). To replace the axle seal you remove the plate (#31), the axle nut, and then pull out the axle. Then you can replace the axle seal (#34).
Aaron
Parts@HoyeTractor.com
(940)592-0181
OH, now I get it. I was looking at the picture but couldn't quite make it work.
thanks for the explination. I'll give you a call this afternoon after my 4 hour dentist appointment (ouch).
thanks
Mark
2007 CHEVROLET BUCKET TRUCK (A52472)
2007 CHEVROLET...
2015 PETERBILT 389 (A52472)
2015 PETERBILT 389...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A52748)
Kubota 24in Quick...
CAT Skid Steer Grapple (A51573)
CAT Skid Steer...
New Long Forks (A53002)
New Long Forks...
