Oil & Fuel YM 2000B Fuel Cup at Glow Plug???
   / YM 2000B Fuel Cup at Glow Plug??? #1
Coyote
North Carolina
Yanmar 2000B & Skat Trak 1300D skid steer
My newly aquired 2000B has a small plastic bottle with a hose at the bottom that goes to the engine between the plugs. Guy says that it drips fuel when you use the glow plugs, but mine is empty.Is that right? Do I just keep a little fuel in it?
   / YM 2000B Fuel Cup at Glow Plug??? #2
Sounds to me like you don't have glow plugs. That is what is used with thermostart. It uses diesel fuel to start a little fire in the intake to heat it. And that is what I have, and it works perfect. The thermostart is used by turning the key to the left instead of the right for a few seconds. If you take the top off of the carb, and look in when you turn it to the left you can see a little flame. That is if you have fuel in the little bottle. It has a little thing that reminds me of a cig. lighter element, that lights it.
Thanks, that's it, I'll just keep a little fuel in that bottle!
   / YM 2000B Fuel Cup at Glow Plug??? #4
The only time you should need to use the thermostart is when it is very cold and the tractor is hard to start.
2016 Kenworth T880 T/A Vactor 2112P-16 Combination Sewer Jetter Vacuum Truck (A50323)
2016 Kenworth T880...
2004 Ford F-250 4x4 Crew Cab Mechanics Truck (A49461)
2004 Ford F-250...
SOLDERING IRONS, GLOVES, AND STANDS (A50854)
SOLDERING IRONS...
2018 PETERBILT 579 SLEEPER (A51222)
2018 PETERBILT 579...
2008 INTERNATIONAL DURASTAR 4300 SERVICE TRUCK (A50854)
2008 INTERNATIONAL...
2006 Toyota Tundra 4x4 Crew Cab Pickup Truck (A50323)
2006 Toyota Tundra...
