YM-2420D right side final reduction pinion and main gear needed.
   / YM-2420D right side final reduction pinion and main gear needed. #1
bill_396
Need good used preferrable or new right side final reduction pinion
and main gear. Not sure if something broke and fell in or whether
just the right side of a pinion tooth broke off but it also damage a
few teeth at least on the main gear. Also any info on what other
models parts will work would be appreciated. Thanks, Bill.
wharris@iserv.net
Re: YM-2420D - similar models
After looking at my disassembled tractor and my cd manual assortment it appears that the various models share far fewer components than I thought. It appears that 240 and 2310 models are different and that the only similar model I have found is a 276. The 276 may have the same large gear but the pinion is different due to a different style of brake. I did have a response from a dealer in Canada who had the large gear but had to check with Japan on the pinion. Problem with that is since their response I lost my hard drive and all the contact info. Anyone know of Canadian dealers that support grey market Yanmars, if I hear the name I will remember it, I had seen it before. Thanks again, bill.
HAMM 3205 SMOOTH DRUM ROLLER (A51242)
HAMM 3205 SMOOTH...
LMC LOT NUMBER 140 (A53084)
LMC LOT NUMBER 140...
2006 International 4300 Water Tanker Truck (A52384)
2006 International...
378630 (A51573)
378630 (A51573)
John Deere S780 Combine (A53342)
John Deere S780...
ASSET DESCRIPTIONS & CONDITION (A53426)
ASSET DESCRIPTIONS...
