YM1110D Trans Drain Plugs Surprise.
   / YM1110D Trans Drain Plugs Surprise. #1
OhioBruce
Yanmar 1110D
Sometimes I wonder what causes more damage - age, poor maintenance, or previous owners.
Yesterday I went to make a drawbar. I found on the forum that there are three holes under the trans that are used to bolt a drawbar to. First thing I did was to remove that plate that was used for the 3-point arms stabilizer chains. I took the first bolt out and trans fluid came pouring out! I noticed there was a rubber sealing surface and the plugs were only held in by a couple of threads.
So a previous owner has used drain plugs to attach this steel plate. The steel plate wasn't even deburred where the holes were drilled.
   / YM1110D Trans Drain Plugs Surprise. #2
I can see why they were drain plugs for each side. I had a Mitsubishi that was the same. hopefully they are strong enough not to break the case. cant imaging how much work it would be to fix that.
I removed the plate and reinstalled the drain plugs and will not attach anything to them.
The three holes for the drawbar are in the tunnel between the two drain plugs. Hopefully they will be strong enough for light duty. I've read of others here on the forum installing a drawbar at that location.
2015 Dodge 5500 4X4 Bucket Truck (A52748)
2015 Dodge 5500...
2005 Ford F-150 Ext. Cab Pickup Truck (A50323)
2005 Ford F-150...
Pequea HR10 Rotary Rake (A50774)
Pequea HR10 Rotary...
New Holland 489 Haybine (A50774)
New Holland 489...
CATERPILLAR 308E2 CR EXCAVATOR (A50458)
CATERPILLAR 308E2...
Year: 2004 Make: Sterling Model: Acterra Vehicle Type: Truck Mileage: Plate: Body Type: Trim Level: (A51692)
Year: 2004 Make...
