YM155D Overheating
   / YM155D Overheating #1
joey4346
Louisiana
Yanmar YM155D
My tractor runs for a little while but overheats. The radiator is good
I suspect the water pump. Where is it????
edited------
well i just found the answer to my question on another forum. there is no water pump.
so my next question is what is making the tractor overheat????
   / YM155D Overheating #2
Too much anti freeze in your water/antifreeze mix can cause those little rascals to get hot........There are some recent threads about this......
   / YM155D Overheating #3
The thermosyphon system won't work well with the normal automotive mix of 50/50 antifreeze to water. It requires a mix of 60/40 (60% water/40% antifreeze) or less.
I use a 66/33 mix because that is easy and it works. Just get a 5 gal water can at Walmart and mark it Antifreeze so it won't ever be used for anything else. Pour one gallon of antifreeze in it and then use the antifreeze container to put two gallons of water in. That is your mix and that should solve your overheating problem.
   / YM155D Overheating #4
It is your water to antifreeze ratio like the others have said. Your 155 does not have a water pump.
   / YM155D Overheating #5
You also have to make sure there are no obstructions in your radiator. Flush it out several times over.
   / YM155D Overheating #6
"The radiator is good
I suspect the water pump."
How do you know the radiator is good? When tractors overheat, it's usually a plugged radiator, either inside or outside.
   / YM155D Overheating #7
Watch the dust build up in the radiator core. If you back flush the core with a garden hose it should rinse the junk out. Be careful not to use to harsh of spray. You don't want to bend the cooling fins. Also, be sure that the engine is cool. Hope this helps.
Dick
thanks to everyone for the replies. i have removed the radiator and flushed it and the engine with clean water. and also replaced the antifreeze with the right mix and all seems to be working ok now. thanks for the help.
p.s. i never realized a radiator would work without a water pump.
neat little system!
TMA (A49461)
TMA (A49461)
2016 Hino 195h Truck, VIN # JHHSPM2H5GK001607 (A51572)
2016 Hino 195h...
2013 JOHN DEERE 8235R LOT NUMBER 205 (A53084)
2013 JOHN DEERE...
UNUSED SWICT 78" QUICK ATTACH BUCKET (A51248)
UNUSED SWICT 78"...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
1994 Toyota 6000lbs 2 Stage Forklift (A53472)
1994 Toyota...
