YM165D Starter 9 tooth or 11 Tooth?
   / YM165D Starter 9 tooth or 11 Tooth? #1
gt14
Aumsville Oregon
Yanmar YM146 YM165D
I just bought a starter for my YM165 tractor. The guy says it is PN S114-230.
The starter I got wont engage the flywheel the pinion gear doesn't stick out far enough. It is also a 9 tooth pinion gear. I have heard that these tractor take 9 tooth or a 11 tooth. How can I tell which starter works for my tractor. I measured the distance from the edge of my gear housing to the edge of the flywheel teeth an it is ~.895" The pinion gear of the starter when fully engaged wont reach. Does someone have any idea's. Do I have the wrong starter the Yanmar PN 124070-77010 crosses to the starter I got from the local guy.
Also I have 2TR13A enigine.
   / YM165D Starter 9 tooth or 11 Tooth? #2
It came from the factory with a S114-219 starter. It is an 11 tooth. Some 9 tooth starters will work because they are offset differently. Some of the 9 tooth aftermarket starters that are being sold as a "Yanmar replacement" are, as you have said, not ling enough to catch the flywheel correctly. I know this because we have a whole pile of them here now that we can't sell for that reason :( .
Aaron
Parts@HoyeTractor.com
(940)592-0181
   / YM165D Starter 9 tooth or 11 Tooth? #3
The starter that came on the the tractor was a S114-219 as Aaron said, part#124060-77011, this number was superseded to # 124070-77010 S114-230 both of the starters have 11 teeth. The price dropped after the supersedure from almost $ 600.00 to a little over $ 300.00. You should be able to get your starter rebuilt or buy a rebuilt one.
Danny
   / YM165D Starter 9 tooth or 11 Tooth? #4
Wy didn't you just count the teeth on the old one?
I was given the tractor by a friend and it didn't have a starter with it.
   / YM165D Starter 9 tooth or 11 Tooth? #6
I wish I had friends like that.:D
Bruce
   / YM165D Starter 9 tooth or 11 Tooth? #7
I see.............
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
2017 TRAILSTART 40FT DUMP TRAILER (A52576)
2017 TRAILSTART...
1999 Toyota Avalon Sedan (A50324)
1999 Toyota Avalon...
2017 Polaris 500 Ranger Diesel Utility Cart (A50324)
2017 Polaris 500...
MI-T-M PRESSURE WASHER (A52472)
MI-T-M PRESSURE...
2015 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2015 Ford F-150...
