YM2200 transmission woes
   / YM2200 transmission woes #1
jimsxl
Hi all,I'm having a hard time getting the input shaft out,this is the one that couples to the drive shaft.We have the shift forks,hydraulic reservoir,front plate,and all the snap ring's off.The front bearing came off easy, and the shaft came out about 1/2 inch then stopped.Isn't that shaft supposed to slide out the front leaving the gears in the case, or does the whole trans. have to be taken apart? I'm in trouble on this one Please Help. Thanks,Jim
   / YM2200 transmission woes #2
It comes out the front, do you have all the snap rings off? We took one out yesterday
Danny
   / YM2200 transmission woes #3
Jim, I think you will have to remove the rear shaft first so you can bump the front shaft out.
Danny
2015 Peterbilt 320 EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
Bush Hog 10' Pull Rotary Mower (A50774)
Bush Hog 10' Pull...
John Deere 5203 Tractor (RIDE AND DRIVE) (A50774)
John Deere 5203...
PALLET OF OUTDOOR ITEMS & MISC HOSES (A51244)
PALLET OF OUTDOOR...
2017 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2017 GENIE GTH-636...
NEW HOLLAND LB75B BACKHOE (A51242)
NEW HOLLAND LB75B...
