YM336 Running temp
   / YM336 Running temp #1
jsal007
Alice, TX
YM336D, Farmall M, Int 560D, JD 4020D
what is the average running temperature for a Ym336 tractor and what is overheating temp.
   / YM336 Running temp #2
The Nebraska tractor test machine ran at about 155-160 degrees in general use, and never exceeded 180 degrees. Their air temperatures were around 75 degrees. Knowing that, if I were running a 336 and saw temperatures over 200 degrees, I would assume my cooling system was somehow compromised. As long as the coolant is not boiling over it's not overheated, but knowing how effective the cooling system on that model is supposed to be, I would start to inspect things were I to see temperatures above what they recorded. The highest temperature they recorded was for the tractor at PTO speed and loaded down as heavily as the engine would sustain, for two straight hours. This is more demanding than most people would ever be on their tractor, so is a good marker for maximum temperatures. The link to the test for your YM336 is http://digitalcommons.unl.edu/cgi/viewcontent.cgi?article=2810&context=tractormuseumlit
Thank you for info.
   / YM336 Running temp #4
Unsure about the temperature but it is important to keep the radiator fins and screen free of debris, chaft, weed seeds, dandelion fluff etc. Mine would get warm when that occurred but as soon as that was cleared away it would cool right down.
2015 FORD-750 XL SUPER DUTY DUMP TRUCK (A51406)
2015 FORD-750 XL...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2018 DODGE RAM 3500 (A52472)
2018 DODGE RAM...
HAMM 3205 SMOOTH DRUM ROLLER (A51242)
HAMM 3205 SMOOTH...
John Deere 310K Backhoe (A51573)
John Deere 310K...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
