Backhoe Your Opinions please
   / Your Opinions please #1
dsgsr
Platinum Member
Monroe, Maine
Kubota M59 ,Takeuchi TB175 Excavator, TD7 Dozer, 2 dumptrucks, Northlander Sawmill
I bought a M-59 TLB last December. Have about 135 hrs on it now. At about 125 hrs. was digging in med-hard clay and heard big bang. Cutting edge on backhoe bucket made clean straight break from where a tooth is welded on too back of cutting edge on diagonal. Kubota says not covered under warranty because it looks like I caught a couple of teeth on something. Huh, I thought backhoe buckets were made for heavy duty digging?
David
   / Your Opinions please #2
I'd file a complaint at the corporate level.
   / Your Opinions please #3
At times things will break...
that's hardened steel so the temper could have been toward the brittle...
A good Welder can fix that up with No problem, I think most all ware edges are excluded from warranty.. KennyV
   / Your Opinions please #4
Probably a faultly weldment leaving an embrittled area at tooth edge. Combine that with the stress riser from the notch formed by the tooth to bucket transition and its all over. Thats asking for a crack to start and they can then progress extremely quickly. It is possible only your bucket is flawed, but its probably an inherent procedural shortcoming in the mfg process. If so it will show up on others like it made by that supplier. I had a break like that on one specific tooth occur on my Loader Buddy bucket. Another purchaser had the same tooth break. None of the others break even used much harder. Probably welding order favored a poor preheat on that particular weld area. Magicheater stood behind it.:thumbsup: High strength steel as in a bucket edge/welded tooth require proper procedures. Yours didnt get it. Stand Kubota up.
larry
2012 Volkswagen Jetta Sedan (A50324)
2012 Volkswagen...
2012 CHEVROLET SILVERADO SINGLE CAB TRUCK (A51406)
2012 CHEVROLET...
ATLAS XAS110 COMPRESSOR (A52472)
ATLAS XAS110...
2012 FORD F-250 XL SUPER DUTY (A52472)
2012 FORD F-250 XL...
2010 Chevrolet Tahoe SUV (A50324)
2010 Chevrolet...
2021 CASE IH 345 (A53084)
2021 CASE IH 345...
