ZD21 overheating (21 HP diesel)
   / ZD21 overheating (21 HP diesel) #1
lawnmover
Kula, HI
ZD21 21HP mower
Aloha all, My ZD21 mower is overheating. I had a bunch of grass in the radiator fins and it overheated. I blew out all the grass, let it cool down. Now it overheats almost immediately.
I'm trying to isolate and discover the problem.
The radiator gets hot on the top, including the hose, but the lower portion is dead cold.
Hopefully I didn't blow a head gasket??
Any thoughts here?? How can I tell if it's the water pump? I replaced the thermostat a few months ago.
Thanks!
Chris from Maui
   / ZD21 overheating (21 HP diesel) #2
Did you check the coolant Level? Sometimes when they overheat they blow off a little coolant.
   / ZD21 overheating (21 HP diesel) #3
You antifreeze is not moving. Start the engine when cool with the cap off and see if it moving your coolant. Your hottest coolant would be on the top of the radiator after the thermostat opens.
2024 Xpro Mini Dirt Bike (A50324)
2024 Xpro Mini...
PREVIEW DATES AND TIMES (A51573)
PREVIEW DATES AND...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A52748)
2017 Yale GLC050VX...
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
2006 JLG 2030ES 20ft Electric Scissor Lift (A51691)
2006 JLG 2030ES...
Toro Z Master 2000 Zero Turn Mower (A50324)
Toro Z Master 2000...
