Zero Turn Leaving Streaks
   / Zero Turn Leaving Streaks #1
jay3534
zebulon nc
AC 5015
I have a husqvarna zth 6123 that is leaving streaks when I mow. Tried brand name blades instead of generic and no change. Air in tires is correct / no changes made except blades / deck is level. Any body have ideas?
   / Zero Turn Leaving Streaks #2
Something has to be off to do that. When I sharpen blades on my two mowers I always stack them together to be sure they're the same. Oregon makes a height gauge, about $10, with mower on flat level allows you to check front to back and side height.
   / Zero Turn Leaving Streaks #3
Scrape the bottom of your deck clean and the streaks will disappear.
thank you for replies / will look at both suggestions
   / Zero Turn Leaving Streaks #5
Also make sure all blade tips are at the same height. Bad spindle bearings can cause the shaft to run crooked.
   / Zero Turn Leaving Streaks #6
Try greasing the spindles
You've probably spun or blown a bearing.
Tap the old bearings and races out.
Then reinstall shielded (ZZ rated) bearings.
You'll never change them again.
   / Zero Turn Leaving Streaks #7
Hmmmm,,, if he leveled the deck using blade tip measurements wouldn't a bad bearing be detected? Or overcome?
   / Zero Turn Leaving Streaks #8
Installing one or more of the blades upside down could do it. It sounds stupid... but all it takes is a few seconds of mind wandering when you are installing them. I have even done it once.
   / Zero Turn Leaving Streaks #9
My elderly neighbor did. His wife asked if I could look at it.... i felt so bad for him. I played it off as no big deal and swapped them. I felt so bad for him....
   / Zero Turn Leaving Streaks #10
Ok...we're on vacation but I just thought of something simple and easy to do, and cheap (which is the best). Matter of fact I'll do it at home! 1) park mower on flat level area...asphalt/concrete 2) with ruler measure deck...front,back,left,right. Maybe try at different deck heights so you verify deck is ok. 3)place all 4 wheels on identical blocks. 4) then you can reach under, wiggle blades (bearings ok?). Then rotate blades by hand and front/back/left/right they all have to be the same. You could simply cut a scrap stick of wood as a guide.
Only thing is be 100% sure mower is raised same all around and safe...can't slip off blocks.
JOHN DEERE XUV835M LOT NUMBER 25 (A53084)
JOHN DEERE XUV835M...
2016 Chrysler 200 Limited Sedan (A51694)
2016 Chrysler 200...
Brushfox XHD-72 (A53421)
Brushfox XHD-72...
Bush Hog R0-720 Roll Over Box Blade (A51691)
Bush Hog R0-720...
2015 ISUZU NPR 16FT BOX TRUCK (A54313)
2015 ISUZU NPR...
2023 New Holland Workmaster 25S Compact Tractor - Only 65 Hours (A53473)
2023 New Holland...
