Zero Turn Options.
   / Zero Turn Options. #1
OhioHick
Medina, Ohio
Ford 2000
I'm in the market for a new mower (or two). I have 14 acres or which I mow 5 to 6 as "lawn" and the most of the rest as "pasture" with a Ford 2000 and a brush-hog (the remainder of the property is wooded). The property is basically flat with a creek running through the front that gives it a little slope in that area but nothing severe. This is old farm land and even after 30 years of not being plowed, it is still not really smooth (at least not golf course smooth but for a country yard I would call it smooth). At present I have two lawn tractors, both from John Deere (48 and 54 inch cut). I ride one and my wife the other and it takes us 4-6 hours to mow depending on how thick the grass is. Both of the lawn tractors beat (both are over 9 years old) so one thought is to replace then with a 60-inch zero turn. We have looked at the local equipment dealers and have the following options on the table: Hustler Fastrak SD (60-in cut, 24 hp), Ferris IS2100Z (61-in cut with either a 26 or 28 hp Briggs engine), Ferris IS3200 Z (6-in deck, 32 hp Briggs or 37 hp or Kawasaki engine) or a Cub Cadet Tank (60-in deck and I think the engine was 26 hp). The Hustler is the least expensive at $7200, the Ferris 2100 is about $9600 with the 26 hp engine, the 3200 is $11.5K with the 32 hp engine and the Tank is $10K. Just looking for your insight on which machine you think is the best option for my property and which is the best value. Thanks!
   / Zero Turn Options. #2
I would go with the Ferris. Now whether you need the 3200 with its series 5400 hydro-gear drive motors or the 2100 with the slightly less 4400 series hydro gear is up to you to decide if you really need it. I would also go with the Kawasaki engine over the Briggs and Stratton just because I think the Kawasaki is a better engine.
I have the IS700Z which has the 3400 series by Hydrogear and FS 691v 23HP engine by Kawasaki and 52" deck. I mow about 6 acres once a week and so far in 2 1/2 seasons, it has been flawless. The engine has plenty of power to go full speed in all but the toughest grass and I can mow it with plenty of gas to spare (at least a 1/4 tank) and it only holds 4 gallons of fuel.
   / Zero Turn Options. #3
OH one thing more, it takes me about 2 1/2 hours to mow my 6 acres mainly due to the large amount(more than 100) of trees, flower beds and shrubs that I have to go around.
Thanks, Gary. I appreciate the input. I have more than a few trees to work around as well, but there are a couple of big open areas as well, so I'm hoping that mowing time will drop.
20 ft. Shipping Container (A53117)
20 ft. Shipping...
2013 Nissan Rogue AWD SUV (A51694)
2013 Nissan Rogue...
2000 WINNEBAGO FORD F550 RV (A52472)
2000 WINNEBAGO...
2019 Fontaine EQ1 Hydraulic Equalizing Spreader (A52377)
2019 Fontaine EQ1...
UNUSED Bubble Aluminum Foil Reflective Insulation (A53117)
UNUSED Bubble...
Metal Pelican Lawn Art (A51694)
Metal Pelican Lawn...
