Forward or Backward
   / Forward or Backward #1
MESSMAKER
Bluegrass,KY
DK4710SE
Which way do you load your tractor? I have done it both ways and I have about decided It is easier to drive it on and back it off. My O.M. recommends backwards but does not say why.
   / Forward or Backward #2
Which ever way loads the truck and the trailer best. Too much weight on the truck is hard on the truck. Not enough weight on the truck (tongue) is dangerous.
   / Forward or Backward #3
Driving forward onto the trailer, there's always the possibility of the tractor flipping over backward if the trailer ramp is steep. The first few times you load can be unnerving, a lot of operators may get scared and let the tractor roll backwards and pop the clutch or engage the forward pedal and cause the tractor to rear up and fall backwards. Also could happen if the tractor has a loader and it's left up too high. It's not going to happen going in reverse. The worst thing to happen is you won't have as good traction backing up the ramp as going forward.
   / Forward or Backward #4
I agree on this 100%. Especially if loading old iron like a John Deer A where your rear end is hanging behind the rear axle. Another issue with my current tractor is the canopy. It takes the wind much better when towing if loaded backwards.
Chris
   / Forward or Backward #5
I always like loading forward..balance trailer..more so w/rear attachments.
   / Forward or Backward #6
I like backing on. I have a cab and I think the rear window would be easier and cheaper to replace if hit by a rock at 50 MPH.
   / Forward or Backward #7
Either way works; just that one may be better than the other in particular circumstances. The important thing is to have the weight distribution right. It so happened that I always drove my Kubotas forward onto the trailer and backed off, but I can certainly understand circumstances that would make the reverse desirable.
   / Forward or Backward #8
proper weight distribution is key, while safety is paramount:thumbsup:
   / Forward or Backward #9
For me, it depends on which implement attached to the tractor. This is because the tandem axles are offset more to the rear (which is how many tandem axle trailers are built). If the bush hog, PHD, or the disc harrow is attached, I will have to back onto the trailer. When I do it this way, usually the tailwheel on the BH, or the auger bit on the PHD will rest forward of the front wall on the trailer. Also, I usually have to raise the FEL, close the drive on ramp, then gently lower the bucket so it rests on top of the ramp so it will all fit on the trailer. That's a drawback of having a 16ft trailer. I could solve that with an 18ft trailer, but I really don't see a need to upgrade just for that one issue.
If I have the boxblade attached, I will drive it on. My trailer has a 4ft drive on tailgate, and the trailer deck is only about 20" above the ground so my ramp is not steep at all and I'm at a very minimal risk of flipping it over backwards during loading/unloading.
Either way I load it, I get the main weight mass (the tractor) centered just slightly forward of the balance point.
One tip a friend taught me is to measure the distance from your rear bumper to the ground before you hook up the trailer. Once you have the trailer hooked up and fully loaded, re-measure the bumper to ground distance again. Typically you want it to drop about 2-4 inches but that varies depending on if you have a 1/2T or 3/4T truck because they have different suspension rates. For most trucks about 200-400 lbs of tongue weight on the rear hitch is good for a bumper pull trailer, that means the trailer & its load are fairly balanced. For GN's this is irrelevant since the GN hitches are bed mounted and designed to handle lots of weight from the GN hitch.
Here's a picture of my towing setup with the bush hog attached:
PS- Don't worry, there's no trains running on that track!! The switch out on the main line was removed a long time ago!! :) I'm parked in an old wood yard where they loaded tree's onto rail cars, but it's now just an vacant 12 acre lot.
   / Forward or Backward #10
kebo,
Do you happen to know what your tractor and FEL weigh? I have a trailer looks like yours with same ramp style but am very leery of trying to use it with new tractor. The trailer would handle it just fine, it's the ramp that may not. Thanks!
BrushFox XHD-78HF 78in Rotary Brush Cutter Skid Steer Attachment (A55787)
BrushFox XHD-78HF...
6 Lug Running Gear (A50775)
6 Lug Running Gear...
Sheets of 12' Tin (A53316)
Sheets of 12' Tin...
14ft. Deer Gate (A53424)
14ft. Deer Gate...
Giyi Mini Land Leveler (A53316)
Giyi Mini Land...
2023 54ft Hooklift Dumpster 20 Cubic Yard (A55788)
2023 54ft Hooklift...
