cabdor
I have a Yanmar 2310D.can anyone tell me where the fuse box is located. I have looked every and can't it. Some say it has wire fuse links. Any help will be greatly appreciated
you don't have fuses either you have the solder wires.After finally getting my fuse panel problems straightened out with a Glass type fuse and repaired the
bad connection everything electrical was working correctly. And has stayed that way. After knowing I corrected them all curiosity was killing the cat so to speak. I have both styles of Regulators old and new. After a few months with no problems I hooked the old one up and it still worked fine. Then I really got brave and wired the Thermal start. And it works : That's been at least 8yrs. ago and I believe I replaced the Neg. Battery cable since then. Which now the battery stays charged and the terminals get cleaned... All the connections for that matter!!
