TX mower
Does anyone know the 4WD Mechanical Ratio for the Yanmar 336D?
This for the purpose of using the lead/lag calculator here to assist in selecting replacement front tires.
By 'reverse engineering' based on the OEM tire specs it seems to be in the range of ~1.60 to ~1.68 but small differences in either the Mechanical Ratio or the tire's spec Rolling Circumference have a big impact on lead/lag when trying to stay in the desired 2%-5% range (closer to 2% but not below preferred), so would like to know the true exact Mechanical Ratio if possible.
Thanks in Advance!
Thanks in Advance!
