Redoing wheels with wrong bolt pattern
   / Redoing wheels with wrong bolt pattern #1
1m21
Member
Dundee, NY
YM2000BD
Cut a plate with the right bolt pattern and center hole diameter.
Using the new plate as a pattern, cut the old center out of the wheel and weld in the new one. Grind/sand smooth.
Sandblasted and ready for powdercoating.
Powdercoated ready to insall.
Now I just have to do the front wheels.
   / Redoing wheels with wrong bolt pattern #2
What a beautiful job and welll done. Thanks for sharing. How did you cut out the new piece. CNC plasma?
Mike
Mike
CNC laser. The plate in the first picture is for the front wheel. The holes were a little tight so I had to open them up a little. The backs were right on and are more representative of the clean cuts the laser makes.
   / Redoing wheels with wrong bolt pattern #4
I did something similar and thought I would add some pics of what I did to make Kubota rims fit a JD 750 I had. (this is my first attempt at pics so we'll see how I do) I don't have a pic of my drill jig, but I drilled 2 holes to match the old pattern and another pair with the new pattern. I would bolt the jig to the wheel and then drill 2 holes for the new pattern. To adjust the center hole I welded in some tubing with the correct ID and close enough on the OD. I bolted the wheel to the axle to tack the center in. Turned out great. Here's the wheel drilled w/the center spacer shimmed in to check the fit.
   / Redoing wheels with wrong bolt pattern #5
Here's where I tacked the center spacer in.
   / Redoing wheels with wrong bolt pattern #6
Finished product. I bought the rims/tires brand new off e-bay for a little over $200 b/c the guy didn't know what they fit!
   / Redoing wheels with wrong bolt pattern #7
1m21 and villagengineer: Beautiful work by each of you.
1m21, what kind of machine do the wheels fit?
They are now on a 1979 Yanmar YM2000BD.
2005 Peterbilt 357 Truck (A55973)
2005 Peterbilt 357...
S/A Fuel Tank Trailer (A59231)
S/A Fuel Tank...
2015 Chevrolet Impala Sedan (A59231)
2015 Chevrolet...
2017 Ford F-550 (A55973)
2017 Ford F-550...
2008 TCE MANUFACTURING 20GN GOOSENECK GEN TRAILER (A58214)
2008 TCE...
2016 FORD F-350 XL SUPER DUTY EXT CAB TRUCK (A59823)
2016 FORD F-350 XL...
