Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 37
  1. #21
    Veteran Member MJPetersen's Avatar
    Join Date
    Feb 2007
    Posts
    1,249
    Warsaw, Poland
    YM 1510-D
    Default Re: Making a 3 point Quick Hitch
    I actually am an American. We are missionaries and have been in Poland for 14+ years. We live on the outskirts of Warsaw and have started a a Baptist church in what is actually a suburb of Warsaw.
    It has been interesting to see the change take place over the last 14 years. Even things like McDonalds. When I first visited in 1992 there was one in downtown, now there are probably more than thirty in Warsaw alone and many of the outlying areas.
    I got the small Yanmar to do some work at the church property and around home. It is my hobby that gets me out of my office and the stress of that. I have worked as a heavy equipment operator and mechanic, which paid for school. My Dad is the farmer; he grows mostly hay both wet baling and dry for horses which he winter boards. he also has livestock.
    But my main job now is pastoring those in our church, and teaching (mostly Old Testament courses in Bible Schools in Poland and Ukraine mostly. So my English is quite good, and my Polish is not bad, but Russian and Ukrainian are not so good.
    I decided to do something special for my rollover to make it conform to the Standard. I hope to finish it tomorrow, maybe. I will post some pics of what I am doing anyway.
    Mike
    "In all your ways acknowledge Him and He will direct your paths." Solomon
    YM1510D, YM 1202 tiller, The following home made tools: Quick Hitch, KK copy dirt scoop, imitation Gannon rollover box blade, Forks on 3pt, a Rear Blade with gauge wheels and a 1.5 yd dump trailer.
  2. #22
    Elite Member
    Join Date
    Dec 2007
    Posts
    3,544
    Ohio
    JD 5520, 790 TLB-- Kub L4300, B7800, MX5100
    Thank you. You truly are doing the Lord's work in two areas and have a land and people hungry for knowledge in both. Congratulations on having the desire and being in a position to be able to influence the lives of so many. Your good deeds may well inspire for generations to come.
    And your welding is pretty good as well.
    For agricultural or technical knowledge, this board is the best out there.
    Don't sweat the small stuff...
  3. #23
    Gold Member
    Join Date
    Jul 2008
    Posts
    447
    20 miles west of Atlanta
    Yanmar 2210BD
    I know of no higher calling. God bless you. Bill
    Try not. Do or do not. There is no try. Yoda
  4. #24
    Join Date
    Feb 2007
    Posts
    1,249
    Warsaw, Poland
    YM 1510-D
    Thank you guys for your very kind words. I appreciate your thoughtfulness. A wise man once said, "For a Christian there is no difference between the secular and the sacred; all things are sacred." What he meant by that is that for a believer in Jesus Christ every calling is a sacred calling. If you are doing God's will it is sacred.
    I had a few snatches of time here during Christmas break to work a bit on conforming my implements to the QH. First I polished the QH up a bit and sprayed some primer on it. Then, I started with the RB and ended with the Rollover. For most part I just did the standard thing to conform them, but the rollover I treated special.
    The RB top link connection was a 1/4 inch low.
    The ball hitch was right at standard.
    The scoop needed its bottom pins spread about 1/2 inch, top is OK not perfect.
    Mike
    Attached Thumbnails Attached Thumbnails Making a 3 point Quick Hitch-chromed.jpg   Making a 3 point Quick Hitch-rear-blade.jpg   Making a 3 point Quick Hitch-trailer-hitch.jpg   Making a 3 point Quick Hitch-scoop.jpg
  5. #25
    Join Date
    Feb 2007
    Posts
    1,249
    Warsaw, Poland
    YM 1510-D
    Now the imitation Gannon rollover was OK on the lower pins, but somehow in the manufacturing I messed up and the top was about 1.5 inches high. It is not a design that would be easy to just lower the hole or drill a new hole. I was going to require some major work to conform it.
    If I was going to do some thing major I might as well do something exciting. So I drew up this curved neck for a top link and cut the pieces out of the old top link mast. Well I had to patch a few pieces together to get sufficient width.
    Then I doubled up on the neck where the pin goes through to give it a bit more strength.
    Then I conformed a 2 inch wide flat stock to separate the posts and provide some stability. I have wanted to try to do something like that for a while and it was a good opportunity. I just heated, bent, and tacked until it was all in place.
    I welded it on the draft tube of the rollover, sprayed some primer on it and it was ready to go. I like the way it looks. It looks special and it was fun to do--although it did take some time. It sort of looks like a penguin sitting there.
    Mike
    Attached Thumbnails Attached Thumbnails Making a 3 point Quick Hitch-patern-pieces.jpg   Making a 3 point Quick Hitch-img_1973.jpg   Making a 3 point Quick Hitch-img_1975.jpg   Making a 3 point Quick Hitch-img_1976.jpg   Making a 3 point Quick Hitch-img_1978.jpg
    Attached Images Attached Images
  6. #26
    Gold Member
    Join Date
    Jul 2008
    Posts
    447
    Yanmar 2210BD
    I sure do wish you were my next door neighbor.
  7. #27
    Veteran Member kthompson's Avatar
    Join Date
    Sep 2008
    Posts
    1,056
    South Carolina
    Kubota M 6800; Kubota B 2710; Gator; Bushhog ZTR; Volvo Mini Excavator EC45
    Quote Originally Posted by MJPetersen View Post
    Mike
    Sure wish more knew that.
    I was impressed before I realize you were in Poland and not Portland and really impressed with your work there. May God Bless you and your family along with those who you are working with teaching.
  8. #28
    Veteran Member GuglioLS's Avatar
    Join Date
    Feb 2005
    Posts
    1,111
    Edgewood, NM USA
    Jinma 354, Ford 1953 NAA Golden Jubilee, Komatsu Bulldozer
    Mike,
    Impressive fabricating skills making your very own quick hitch. I read your "Imitation Gannon" roll over blade project and I must have missed that one during it's construction. That is the best home made Gannon blade I have ever seen. You sure did good on that as well, equally impressive is you did it all with common hand tools, so my hat's off to you. Now I suppose I should stop telling all those Pollock jokes, well maybe all except the one about the two Pollock carpenters nailing siding on a house. The master carpenter was watching his apprentice nailing the siding, as time went on, he noticed the apprentice throwing about half the nails onto the ground. The master carpenter asked the apprentice why he was throwing away so many nails. The apprentice replied "Because the head of the nail is on the wrong side" The master carpenter disgustingly shouted out to the apprentice "You moron, you should save those nails for the other side of the house"
    Mike, your projects are tops and I look forward to many more.
    Larry
    My Fortune cookies:
    If you have to ask if you can do something, you probably can't.
    Life is short, especially if you forget to wake up the next day.
    He who hurries wastes time.
    If you must select between two evils, choose the one you haven't tried before.
    Tractor hydraulics is not rocket science.
  9. #29
    Join Date
    Feb 2007
    Posts
    1,249
    Warsaw, Poland
    YM 1510-D
    Thank you very much for the kind words. I really do enjoy making something useful and practical.
    Larry, considering that you and Rob or the kings of special fabrication/modification, I take that as a very high praise indeed. Thank you very much--I have read every thread of your constructions with real interest. With every project you have upped the ante. I have not seen any new projects lately though. You have something on the back burner?
    Pollack jokes are rather popular, the national subject of such jokes changes with the country that you reside. Here Russians are often the subject.
    One funny joke deserves another-- 3 friends were carpooling to work, one was a Pole and the brunt of the Pollack jokes of the other 2. The Pole just sat quietly looking out the window. The 2 ask, "What's the matter, you do not think our jokes are funny?" The Pole replies, "Can you read Polish?" The 2 reply, "NO, of course not." Silence. . . Pole, "Can you speak Polish?" The 2, "NO, who would want to?" The Pole just stares out the window. The 2, "What is all this stuff about reading and speaking Polish?" The Pole, "Well I was just wondering, what is it like being dumber than a Pollack?"
    Well back to topic---I discovered something yesterday that I had not anticipated--well I should have if I had thought things through.
    I was using my scoop in the reversed position--back into a pile mode--as a large dust pan. Normally, when I dump it I can just reach back and trip the mechanism, however with the QH, I cannot easily do that, the hitch blocks me and I cannot reach the trip without being a contortionist. I am going to do something about that--beyond the rope that is normally used in the forward scooping position. Have to think!!!
    Have a GREAT New Year!!!
    Mike
  10. #30
    Gold Member
    Join Date
    Oct 2007
    Posts
    331
    Western Europe
    Kubota B7100D
    Its nice to see your "petersen rollover blade" with some dirt and rust on it Mike.
    I am seriously considering making my own shortly. You have made it easy for us to follow...
    I like the new goose neck mod for the top link on the rollover...
    Just a question regarding the quich hitch locking mechanism Mike... Can you elaborate on how the mechanism works? Maybe a sketch?
    Thanks,
    b
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
