Fuel Storage Tank and Stand
   / Fuel Storage Tank and Stand #1
GIJOE
Gold Member
Baton Rouge, La.
MAHINDRA 3510 w/ ML112 FEL
Here is a fuel tank stand I built for a 75 gallon tank from a Mack truck. The skids are built out of 6" channel iron with 1-1/2" ID pipe used for the spreaders. 3" flat bar was welded to the open side so it could be securely transported by a set of forks. The cradles were made from a section of trailer house frame with a strip of 1/8" sheet metal cut 3" wide and welded in place to hold the tank. The upper part of the frame was made out of the same 1-1/2" ID pipe and 1-1/2" square tubing. A shackle was cut and welded on top to be used as a lifting eye, and a piece of 1/4" plate was used for the mounting location for the hand rotary pump. Brass fittings, valves and fuel hose finish off the plumbing.
Enjoy.
   / Fuel Storage Tank and Stand #2
Enjoy.
Neat
Good Job.
Do you fill it with off road?
   / Fuel Storage Tank and Stand #3
Cool, good idea using a truck fuel tank, nice job.
   / Fuel Storage Tank and Stand #4
Geez !! I knew I should of kept that passenger tank off the side of my truck when it was replaced last winter after being banged in the side by a half-wit who did not scrape the ice off of his side windows , ( barely had himself a 6" hole scraped in the windshield to see through :mad: ) . That was a 100 gallon model with 2 dings in the side towards the bottom , roughly the size of a baseball each . Cost for new tank ............. $1600 !!!!!
Course , his insurance bought it , so I was not to concerned about the cost .
But for others , that is a good idea . Go check at truck dealerships that do body work . The local freightliner dealership here had a couple of tanks behind their body shop awhile back . Any dings like mine are not fixable , since the aluminum is streched , so guess they would go to scrap ??
Nice work . ;)
Fred H.
   / Fuel Storage Tank and Stand #5
Makes me feel like a cheapskate! I'm using a couple of 55 gal. drums I paid $5 apiece for. Picked up a Gasboy handpump at a garage sale for another $10 (had to put a gasket kit in that). Lifting a full drum out of the back of the pickup with the frontloader is a bit touchy though. The truck fuel tank is a really good idea!
Thanks for the compliments guys.
When I bought this house I'm living in now, several years ago, the tank was in the backyard. I was originally going to get rid of it, but I couldn't find anyone to take it. I even set it out by the road for the garbage man to pick up but they consider a fuel tank hazardous material and wouldn't touch it. I carried back up to the house, and after it set in the back yard for a couple of years, I got the idea from this forum to build a storage tank.
LBrown59,
I just finished it couple of weeks ago and have not had time to fill it yet, but yes, it will be filled with off road fuel.
harwill,
Lifting a full drum out of the back of the pickup with the front loader is a bit touchy though.
Yes, I know what you mean. That is why I built this to be lifted by a set of forks or from the lifting eye.
Joe
   / Fuel Storage Tank and Stand #8
1*Lifting a full drum out of the back of the pickup with the front loader is a bit touchy though.
harwill,
2*Yes, I know what you mean. That is why I built this to be lifted by a set of forks or from the lifting eye.
Joe
1234567890
1* & 2* I wrestled with this till I realized I had a pump to pump the fuel out of the drum .
I don't do any handling of drums of fuel.
You did a great job on the tank:
Only thing I'd have done different is to have plumed in another hose on the pump.
1234567890
LBrown59,
3*I just finished it a couple of weeks ago and have not had time to fill it yet, but yes, it will be filled with off road fuel.
3*I get my fuel delivered even though It's only 25 to 55 gallon at a time.
Have you checked that out.?
Cost me the same if I go get it.
   / Fuel Storage Tank and Stand #9
Makes me feel like a cheapskate! I'm using a couple of 55 gal. drums I paid $5 apiece for. Picked up a Gasboy handpump at a garage sale for another $10 (had to put a gasket kit in that). Lifting a full drum out of the back of the pickup with the front loader is a bit touchy though..
Park the loader/use the pump.
   / Fuel Storage Tank and Stand #10
Neat
Good Job.
I don't want to sound stupid but what is off road diesel, and where could I get it,is it less expensive.
