AKfish
Super Member
- Joined
- Oct 1, 2004
- Messages
- 5,417
- Location
- Alaska
- Tractor
- JD 5115M; JD 110 TLB; JD 4720; Ford 9N; JD X300R
I looked the 110 and just happened to glance at the M59 that was also at the dealer and personally I thought the M59 to be a quite a lot larger.
M59
8344 lbs
Net HP 57, PTO HP 46
Loader breakout force 5961 lbs
Loader Lift capacity 3968 lbs
BH digging force 7602 lbs (bucket)
BH digging force 4731 lbs (dipperstick)
110
7280 lbs
Net HP 41, PTO 33
Loader breakout force ???? lbs
Loader Lift capacity 2042 lbs
BH digging force 5723 lbs (bucket)
BH digging force ???? lbs (dipperstick)
* Not sure I have all the 110 numbers completely accurate.
L45
7173 lbs
Net HP 42.5, PTO HP 32
Loader breakout force 4530 lbs
Loader Lift capacity 2848 lbs
BH digging force 5825 lbs (bucket)
BH digging force 3779 lbs (dipperstick)
You're right... you don't have the 110 statistics "completely accurate". Like any statistics - you can quote them to support your position - or you can make the extra effort to ensure that you're comparing "apples to apples".
The Kubota stats for the loader's (both the M59 and L45) are measured "at the pin" - not 24" forward of the pin. Even there, the 110 is (from www.tractordata.com):
Breakout force (lift): 3,965 lbs [1798 kg]
Breakout force (bucket): 4,855 lbs [2202 kg]
Lift to full height (at pin): 2,727 lbs [1236 kg
The 110 specs out very closely with the L45 and the L48.
The weight of the 110 is ~7,800lbs with the backhoe. With optional equipment - belly pan, stabilizer shields or the 4n1 bucket, etc. - the weight will edge over the 8,000lb mark.
Physically, the 110 appears to be "bigger" than either the L45 or the L48. Alot of that difference is tires. But, not all... as the 110 weight difference with the 45-48 is about the same as the weight difference between it and the M59.
AKfish
