Kubota Inferior Tires!!
   / Kubota Inferior Tires!! #1
Giles
Florence Alabama
2009 Kubota B2320---Wheelhorse lawn mower--- Case 480D Backhoe
I finally go tired of having to add air to both front tires on my B2320. I added "slime" and it helped, but there was always green liquid slime that seeped out of both tires. Even the sidewalls!!
Just a shame that I bought a new tractor and I get INFERIOR TWO PLY CARLISLE tires.
Since my tractor has a loader, I was afraid to load the front bucket for fear of blowing the front tires that were inflated to their max at 22 psi.
Dealer wouldn't do anything and I figured new Carlisle tires would be the same quality.
I just bought and installed BKG LG-306 EIGHT PLY tires and the total price was $173.53!!
Quite another shame that these India made tires are far better quality then the American made Carlisle!!
I always try to buy American but the only tractor tires I could find, made in USA, were Carlisle!
   / Kubota Inferior Tires!! #2
That price isn't bad, except that they replaced new tires....:ashamed:
   / Kubota Inferior Tires!! #3
Chilly807 was able to get his replaced for free recently from Carlisle after he whined to them. His were on a L3400. Mine were not Carlisle They were Titans. Well it looks like your problem is solved, and probably a lot better tire, too bad about the money.
James K0UA
   / Kubota Inferior Tires!! #4
Just got Max28XL with Industrial Carlisles. 4 ply 35psi front. 6 ply 40psi rear. 1400lbs FEL rated lift; 2700lbs breakout. 2200lbs 3ptHitch lift cap.
I really hope those tires last me decades...
   / Kubota Inferior Tires!! #5
It would have been a lot cheaper to tube them, I did that on my new ones. The old ones had sidewall bulges, which I suspect I caused due to running too low a pressure during loader work. Check your loader manual, I suspect you'll find a different pressure spec for your tires.
Carlisle stands behind their products 100%, regardless of how they are to begin with. Really easy company to deal with.
Sean
   / Kubota Inferior Tires!! #6
James K0UA
I wonder if that was like a hydro whine, or maybe a coyote curled up in front of the fire kinda whine...:laughing: Curious now, what does Kioti put on theirs? The last Kubota's I looked at new had anything from off-shore mystery brands to Titans.
Sean
   / Kubota Inferior Tires!! #7
Giles,
I feel your pain. I had problems with the front tires on both my BX25 and B3030. And I don't want to hear, "What can you expect from tubeless tires?" I once carried 2,600lbs of stone from a quarry in the back of my 1/2 ton Silverado pick-up. It had tubeless tires and I got no flats. Most equipment trailers also have tubeless tires and are rated to carry 4 tons or more. Here's a flat on my B3030 after purchasing it new and having it only for 4 months:
   / Kubota Inferior Tires!! #8
Sean
Same as the 'bota.. Titans. By the way the Kioti, has like no hydro whine..You have to be in HI range and trying to pull a hill to make it whine at all.. The L3400HST wasn't bad but this one is quieter. My neighbor had a bx for a while. and when we were both out pushing snow one day, I could hear his bx whine over the engine noise of my L3400HST. Now that was loud.
James K0UA
   / Kubota Inferior Tires!! #10
James K0UA
It seems like it's the smaller Kubotas, like the BX and B series that are the loudest. I've got a Craftsman lawn tractor with hydro, and I find it louder than you'd expect for something that small. Great for mowing, I will say that much.
Sean
