allen in texas
- Joined
- Oct 26, 2007
- Messages
- 916
- Location
- Levelland, TX
- Tractor
- Kubota Grand L 5740, loaded R1's w/640 lbs cast weight, 854 loader
A lot depends on the brand of plow. I pulled a 3 - 14" bottom xxxxx plow for about 10 years and my tractor stayed in a strain about all the time. I added wheel weights, front suitcase weights, maximum tire ballast on the tractor and trash boards and moldboard extensions on the plow. Plowed with coulters installed and without. Made no difference.
Then one day, I bought a XXXX brand 4-16" bottom plow to resell. It was in the spring and I had about 40 acres to turn, so I decided to see if I could even budge the 4-16" behind the same tractor that I had used on the 3-14" for 10 years. I not only pulled it, I ran with it. The tractor seemed to not even know it was back there. The fields looked excellent. I learned a lesson that spring that there is definitely a difference in how each brand of plow pulls. Ken Sweet
Hey Ken,
What brand pulled hard?
PS I have watched a ton of the You Tube plowing (ploughing) videos. BIG tractors going real fast sometimes. You can see smaller tractors plowing slower too.
I like 'em too.
