84" Too much bucket for Kubota M7060 HDC12?
   / 84" Too much bucket for Kubota M7060 HDC12? #1
tflt
Member
N/Y
Kubota M7060HDC12, kubota L4300 DT, John Deere X500
Can anyone offer any first hand opinion on using an 84" bucket with the LA1154 loader, on an M7060HDC12? If I want to cover my tread width when the rears are set out, (16.9 - 30 tires), I need to move from the 72" to the 84" bucket. I was wondering if that might be too much bucket for this machine.
Thanks for your thoughts!
Patrick
   / 84" Too much bucket for Kubota M7060 HDC12? #2
Patrick
If your moving lighter loose material you'll probably be fine. I have the LA1353 loader on my 8540 with 84" the loader has 1500lbs more break out force and lift capacity to 60" and over 1000 lbs to full height. I have a lot of clay lifting a full or nearly full bucket out of a pile sometimes I dont quite have enough breakout force.
I suspect youd be fine for most applications
Thanks for the reply Dave, what's your opinion of covering the tread width of the rear tire completely?
   / 84" Too much bucket for Kubota M7060 HDC12? #4
Hi Patrick its definitively nice if youre clearing snow. Normally in the dirt your not removing more than an inch or so at a time. I suspect its not a problem if it tires dont completely cover the rear. Perhaps someone else can comment as i dont really have experience with that condition
Regards Dave
   / 84" Too much bucket for Kubota M7060 HDC12? #5
I have a 84" on my M7040 with cab, rear tires filled, cast center wheels. I like it. I wanted to cover my tire width and have the larger capacity for snow. Also keep in mind you might not always have a full bucket but you can move the equivalent amount of the 72'' bucket and not spill any if you have to travel while carrying material. Hope I made sense. I say go with the 84".
   / 84" Too much bucket for Kubota M7060 HDC12? #6
Regards Dave
The stock bucket that came with my mahindra was way too small. The bucket I have on now is a bit oversized for dirt work, but I find it's a great all around bucket. The original, smaller one was not able to load wood chips-it just moved the pile unless you had something to push against.
A larger bucket is better for: firewood, raking debris into it, snow, any lightweight material.
The only downside is you might not be able to lift a heaped bucket in tightly packed material, and you may need to run more counterweight if using the loader and bucket to its capacity.
Go with the 84" IMO if it's a general use attachment.
Thanks for the replies, I see the pros and cons, and am considering all of your thoughts!
   / 84" Too much bucket for Kubota M7060 HDC12? #8
Multiple buckets. I have a 78" digging bucket and an 84" materials bucket. These have worked out excellent for me. :thumbsup:
   / 84" Too much bucket for Kubota M7060 HDC12? #9
Have a 78" on LA1153E loader on a M7040SU. 72" looked too narrow. 78" is width of tractor but my wheels are set in close.
   / 84" Too much bucket for Kubota M7060 HDC12? #10
If I moved any snow I'd want the wider bucket.
My bucket work is heavy material. I run an 84" and a 72" on a 90" tractor.
