Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
  1. #21
    Join Date
    Nov 2007
    Posts
    790
    PA
    Kubota L3130 HST 4x4
    Default Re: Kubota L3130 Hydraulic accessory block
    I don't know if it will help, but attached are a few photos from my 723 loader instructions.
    (Not one of the photos below)In Section 3.2 Checking Parts they show item 9 as a Hydraulic Block [L2203, L2213, L2223, L2213A, L2223A]
    Item 1 in the 2nd photo below is the Hydraulic Block referenced in Section 3.2 (Reference above)
    Kubota L3130  Hydraulic accessory block-block-1-jpg Kubota L3130  Hydraulic accessory block-block-2-jpg
    Kubota L3130 HST 4x4, FEL LA723 w/QA and BH90 Backhoe
    Kubota L4740-3 Cab, HST, FEL w/Heavy duty bucket w/cutting edge
    Snow Blower: L2185 72" front mount w/hyd rotation and electric chute, 7' back blade, carry all, 48" Pallet Forks w/QA, Sun Shade, Turf tires & Rubber Chains for the winter, Extra forward and rear lighting. BearCat 73454 Wood Chipper. LandPride RCR2672 Rotary Cutter. Ballast Box Approximately 390 hours on L3130
  2. #22
    Veteran Member deepNdirt's Avatar
    Join Date
    Sep 2009
    Posts
    2,315
    Nth East Ga, USA
    yanmar YM-1700
    Update: we got the adapter block installed and all the lines connected, it took a few minutes to work the fluid throughout the loaders hydraulics cylinders etc, all is up and working , the loader arms lift strong as well as curling the bucket strong and can lift the tractors front off the ground, ...However! something doesn't seem right about the lowering of the loader, it seems as though they are free falling when pushing the control lever in this position, actually I beleave would slam to the ground if let do so, but I stop short of the ground and it will shake the tractor, I'm afraid it could lead to breaking something withen the loader tower conections and supports, Though if I very slightly move the lever in the lowering position the loader will drop slowly as it should all the way down, anyone have an idea of whats going on?
    or if any adjustments I should make? I've looked everywhere on the spool and cannot find a relief valve or any such adjustment screw, ...........
    at first I thought maybe the lowering side of the cylinders were not pressurized But but when I slightly press the lever /spool inwards as I said the loader goes down slow as it should, so isn't this indication the fluid is in fact pressurizing this side of the cylinders?
    I know with the loader on my Yanmar I sometimes get impatient because of how slow it comes down But I certainly wouldn't want it to come down this quickly,
    Thanks in advance
    Never judge a man until you've walked a day in his shoes,
  3. #23
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    18,924
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    Maybe you are going into float mode.
    As you press the lever, it will allow a small amount of fluid to flow, and if you press more to the soft stop, the operating time will decrease and arms will lower faster, and if you go past the soft stop, you will be in float mode and all ports on that spool are open to tank.
    Is it possible that you connected the hoses wrong, and if the valve has regen, the arms will lower fast.
    Regen is supposed to be in the bucket circuit.
    If the regen circuit is connected to the lift arms, the the hyd circuit will provide a fast operation.
    Can you show some pictures of the hyd block , and the loader valve.
    If your loader valve is the first valve in the system, it needs a relief valve, unless the hyd block is providing the relief for the loader valve.
    You need to check the relief pressure, and ensure the loader valve is protected.
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  4. #24
    Join Date
    Sep 2009
    Posts
    2,315
    Nth East Ga, USA
    yanmar YM-1700
    Thanks JJ, I'm not sure about the floating, though could be, I do know that it would be difficult to get used to especially while sitting on the tractor moving about with hand on the lever trying to carefully and barely push the spool inward, I can only imagine what it would be like with 500 lbs. load in the bucket what might happen, so should there be a way to set this spool up to Not have the floating ability? only adjustment I could find is there at the linkages behind the lever, There are small ball & socket on a threaded rod that looks like can be either adjust in or out that might help control how far the small pistons will move inward, although on the side that lifts/lowers has some sort of a stop surrounding it that I can see would not help, I suppose I need to get a photo of this and let y'all check it out, maybe then can see what needs to be done?
    Thanks again
  5. #25
    Elite Member wdchyd's Avatar
    Join Date
    Apr 2010
    Posts
    2,886
    Hooksett, NH
    Kubota B2320
    DeepNDirt,
    If ya get backed up against the wall and the hoses seem to be hooked up right (if it's not a regen problem) then you could install one of these inline at the main control valves at the extend hoses to help tune it to slow down when retracting
    Surplus Center - 3/8 NPT 8 GPM PRINCE WFC-600 IN-LINE FLOW CONTROL
    2010 Kubota B2320 FEL & BH65
    If it ain't fixed don't broke it!
    http://www.tractorbynet.com/content/...-month-wdchyd/
  6. #26
    Join Date
    Sep 2009
    Posts
    2,315
    Nth East Ga, USA
    yanmar YM-1700
    Quote Originally Posted by wdchyd View Post
    DeepNDirt,
    well I did have to take all 4 of the lines off and have them shorten and have new compression fittings installed, I don't think I got anything backward or crossed up, But always a possibilty
  7. #27
    Join Date
    Sep 2003
    Posts
    18,924
    JACKSONVILLE, FL
    Did you check out whether you had float?
    When you push full forward on you lift arm lever, does it lock in detent, and to release it from detent you have to pull the lever back to spring loaded neutral?
    J.J.
    Git er done.
Similar Threads
  1. Replies: 4
    Last Post: 07-25-2011, 09:17 AM
  2. Kubota L3130 engine block needed
    By FTCKUBOTA in forum Kubota Owning/Operating
    Last Post: 09-13-2009, 09:24 PM
  3. Kubota B7800 Hydraulic Block
    By tamarack in forum Kubota Owning/Operating
    Last Post: 06-17-2008, 12:14 PM
  4. Check Kubota L3130 Hydraulic Pressure
    By smittyd3 in forum Hydraulics
    Last Post: 11-09-2005, 07:10 PM
  5. Check Kubota L3130 Hydraulic Pressure
    By smittyd3 in forum Parts/Repairs
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
