NewHollandDLR
tractorlogger said:Does anymone know what model tractor JD are using for the 110 TLB, is it just one of the other models painted yellow or is it a machine made just for the 110 TLB functions??
Thanks
The transmission and motor come directly from the JD4610 tractor. The rest of it is all its own. You will not have issues with the tractor pulling itself apart like the 4510, 4610 and 4710 tractors did when equiped with the larger backhoes like a Bradco 611 and 4 in 1. The green machines were made as homeowner or farmer type tractor. They were never intended for construction use. When put to this type work over a period of time the bellhousing to the motor bolts being a stress member (no frame tying front to back together) they would break bolts and litterally tear themselves in two. I took a 4710 in on trade that came on 2 trailers because of exactly this issue. The 110 has remedied this by way of a full frame to take the stress and the abuse of a construction grade tractor.
JD Dlr
