Volfandt
I owned an 04 L130 for a season. 23hp w/a 48" deck. It mowed very well, the mulching kit worked good, the bagger also worked good and was easy to mount/dismount. The HST barely whined and I never bogged down the 23hp Kohler when mowing.
Only mechanical negative I had with it was that the CV Kohler smoked on cold startup way to much for my likeing. I'm not a big fan of the Kohler CV Command where as I think the Kohler K series is the best air cooled engine ever made.
I also found out that none of the 3 JD dealers in my area wanted to provide warranty service work on it, one of which was the assigned dealer. I finally got a Kohler authorized shop to repair the defective reed valves and after the repair I decided to not deal with my local JD dealers. But thats another story
I then sold it for what I had in it (JD sells) and bought a Kubota BX23.
I would venture to say that a 100 series would compare similar in operation to a 200 or 300 series that had the same HST (Tuff TorQ K46) and similar HP, but I'd also say that the 200 or 300 series will have a better engine (Kawasaki as compared to the B&S), thicker frame, stouter steering assembly and more ergonomics. Gotta justify the extra $$$'s.
That said, For an inexpensive economy mower the 100 series seem to be a good deal.
Can't compare it to any other JD L&G tractor as I've never operated another.Since you have seat time on the "Box store" 100 series, can you compare it performance wise to a JD "GT" series garden tractor
