couldnt get it to move the brake was disengaged and was in neutral
The owner's manual is a good investment for all users. I've picked up a number of different OEM manual's on eBay that were in very good condition and inexpensive.
If you don't run across a manual for a 110TLB, you can order one on the JD website or from your local dealer as well.
Hi thank you for the quick response. Sorry wasn't so exact. I had the brake off placed it in gear and throttle. it wouldn't move and when i pressed the gas or brake pedal the manual light flashed on and of when pressing the peddle. it doesn't appear any leaks because it would be noticeable with the snow. i thought maybe its a safety mechanism. hope this helps better to get the feel of what might be going on.
Its the N label. I did everything properly to start it. The n flashes very quick when i hit the forward or reverse or even the warning level when going in reverse
i bought it from Histands in PA, what till i get on the phone. I can start the engine in A,B, or C. without the brake on. Isn't that a safety hazard? i have a feeling something popped in the range shifting.
AK, did you read my post at all?
How does the range lever feel? Do you feel detented positions for the A-B-C ranges and neutral? The neutral safety switch is incorporated into the forward and reverse pedals. If you push one of the pedals, it should not start. How about the seat safety switch. If it is not working, it will not move. I have seen some seats "freeze" in cold weather and the cushion does not flex enough to activate switch. I have also seen some "light" operators have trouble activating the switch sometimes. If all that checks out, you probably have either a loose wire or a sensor that is bad or needs adjustment.
