RobertN
Super Member
TnT is Tip and Tilt or Top and Tilt.
The top link of your three point hitch is replaced with a hydraulic ram, as is one of the side link. Then, you can tilit you scraper or other implement side to side, or tilt it forward/backward. For instance, you might want one side of your scraper or grader blade set lower than the other to clean a ditch. Simply move the hydraulic lever.
You can make the same adjustments with your existing toplink or side link. It just makes it a lot easier on the fly.
Thanks for the replies. Although I have a Kubota TLB now, I'm not very tractor savoy. Please explain what a "hydraulic top link" and "TNT" is, what it's used for and is an option that the dealer can install? Also, what do you guys use the remotes for and why would I need as many as three? Thanks.
