TODAYS SEAT TIME
   / TODAYS SEAT TIME #2,502
Yep, push the joystick all the way forward and the boom floats. Digging angle is the curl function, tilt is aux hydraulics slide switch on the joystick.
That is a 3 point to SSQA adapter on the boxblade
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=311147"/> <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=311148"/> <img src="http://www.tractorbynet.com/forums/attachment .php?attachmentid=311149"/>
thats nice i lick the tilt feature Would be really slick if the box blade could be turned around like a snow pusher
   / TODAYS SEAT TIME #2,503
thats nice i like the tilt feature Would be really slick if the box blade could be turned around like a snow pusher
Pushing with a box blade On a FEL doesn't work well, unless it is loose dirt. Pulling backwards with the arms in float and using curl to change the digging or dragging angle of the box blade does work well.
That is the way it works on this machine, but it is front wheel drive, so a rear drive or 4WD might be different.
This was a pile of loose dirt, 4' box blade.
Ripper teeth down, float mode, backing up.
   / TODAYS SEAT TIME #2,504
I put my neighbors box blade on the 3PH and smoothed up some of the worst rutted spots between his place and mine. Still too wet with snow still on the sides in places so I'll need to do the whole road in a few days when it dries out.
   / TODAYS SEAT TIME #2,505
This morning I cut the last wood I am going to get for quite a while. Won't be any more seat time untill the frost finishes coming out of the ground and things dry up. I took the chains off and put the tractor in the garage. Time to do maintenence on the equipment and all those little motors of summer. I am looking forward to some warmer weather
   / TODAYS SEAT TIME #2,506
View attachment 312268 View attachment 312269
View attachment 312271 View attachment 312272
I guess when i think about the physics involved what your saying makes perfect sense. Thats a very interesting contraption you have there
   / TODAYS SEAT TIME #2,507
Thanks, is is very powerful and maneuverable, for its size.
Here is the link to the put-together: TORO+Loader
   / TODAYS SEAT TIME #2,509
Today I decided to do a little roadside trimming under the powerline while I wait for spring.
   / TODAYS SEAT TIME #2,510
Seams like Mother Nature wants to drag it out this year. Spring is coming, but every time it looks like the weather is going to warm up it doesn't. Like everyone else around here my driveway needs work yet there's still too many places that are still thawing.
JOHN DEERE 4066R LOT NUMBER 23 (A53084)
JOHN DEERE 4066R...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A53472)
80in HD Tooth...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
2012 UNVERFERTH 15-INCH REAR SPACERS FOR 10 BOLT HUB (A53472)
2012 UNVERFERTH...
