Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
  1. #11
    KMA
    KMA is offline
    Gold Member
    Join Date
    Sep 2006
    Posts
    276
    Owego, NY
    PT422 w/ EH72FI engine swap
    Default Re: My PT-422 mods
    Quote Originally Posted by wasabi View Post
    I'm considering an improved tilt seat for my retrofit PT2445 slope mower. Any regrets on the one you chose after using it?
    Actually yes... I've since reverted back to the stock seat and removed the TSC seat from my PT although it did help absorb the bumps. When I first built my home a few years back, there was no grass and my clay soil hardens like a rock. So as I drove around and did work my kidneys took a good pounding. The springer seat helped a ton with that. Unfortunately, it sits you up quite a bit higher such that my wife and son couldn't drive the tractor comfortably. The other issue with the TSC model's design is that it tilted slightly side to side, making it uncomfortable to drive across hills and when using the mini hoe on sloped areas. There were a few other minor annoyances too like it wouldn't stay put in the forward position when opening the engine compartment.
    I think a lower profile seat that is more stable but still takes some of the impact out of driving over rough terrain would be a better choice. The TSC served it's purpose and now that my property is coming along it isn't quite as rough to drive on so the stock seat is fine.
    Good luck!
    BTW I've installed a simple fuel shutoff valve based on the advice found on this forum. I will try to take a few pics and post here when I can.
  2. #12
    KMA
    KMA is offline
    Gold Member
    Join Date
    Sep 2006
    Posts
    276
    Owego, NY
    Per the suggests of forum members, added a fuel shutoff valve for when the tractor sits for extended periods of time. Fashioned a simple bracket under the driver side of the fuel tank so it would be easily accessible and not resting against anything hot.
  3. #13
    KMA
    KMA is offline
    Gold Member
    Join Date
    Sep 2006
    Posts
    276
    Owego, NY
  4. #14
    Gold Member Clumber's Avatar
    Join Date
    Sep 2010
    Posts
    322
    Northern Virginia
    PT425 (Dec 2010)
    Quote Originally Posted by KMA View Post
    Nice work on the engine transplant!
    Would a Fuel Shutoff valve still be recommended for a new PT 425? I vaguely remember the reason was gas continuing to flow into the carb even after key turns off the tractor ???? Just wondering if its still a problem with the newer engines. I have never smelled gas after parking the PT in the garage for several days.
    Patrick
    I married me a hippy, ran away with a stringy haired blond,
    Now we're both old and happy, fishing on our own Golden Pond. -- Merle Haggard
    PT 425 (Dec 2010), Blade, Snow Blower, Sweeper, Spreader, LMB, 4n1, Small Bucket/Teeth, Utility Grapple, Brush Cutter, Box Blade, Mini Hoe/Thumb, Forks, Power Dumper
  5. #15
    Silver Member Red Zebra's Avatar
    Join Date
    Apr 2007
    Posts
    149
    Fox Meadow TN
    '07 PT 425
    Quote Originally Posted by Clumber View Post
    I had the aforementioned leak happen 1x to my 425. Added a $5 shut off valve and now no worries.
    I sometimes forget to shut it off. Even "funnier" is I forget to open it. The 425 will run about 10 sec before sputtering out. It surprises me every time.
    The 1x it happened, gas flowed into the carb it also flooded one of the cylinders. I had to pull a plugs and turn it over a few times to void the gas before reinserting plugs. Warning! Gas comes out of the plug whole at warp speed/spray! Put a few shop towels over it to "catch" the discharge.
  6. #16
    KMA
    KMA is offline
    Gold Member
    Join Date
    Sep 2006
    Posts
    276
    Owego, NY
    Clumber, I've used the shutoff valve if the tractor sat for relatively extended period of time. An easy example is over winter or maybe if I knew I wasn't going to use it for a week or so. During the summer months I rarely turned it off. Good luck!
  7. #17
    KMA
    KMA is offline
    Gold Member
    Join Date
    Sep 2006
    Posts
    276
    Owego, NY
    Added a customized Subaru OEM exhaust kit made for their v-twin engines:
    PT422 engine swap completed (with pics) - Page 2 - TractorByNet.com
  8. #18
    KMA
    KMA is offline
    Gold Member
    Join Date
    Sep 2006
    Posts
    276
    Owego, NY
    Converted a snowblower using the motor from my finish mower: http://www.tractorbynet.com/forums/p...ml#post2661500
  9. #19
    KMA
    KMA is offline
    Gold Member
    Join Date
    Sep 2006
    Posts
    276
    Owego, NY
    As a temporary fix to the exhaust kicking up dust and burner grass when stopped, I added a simple copper elbow a few years back. Sometime later I swapped out the exhaust for a modified Robin model, but it wasn't sturdy enough to be mounted outside the tub (it was designed to be bolted directly to the side of the engine). I eventually went back to the PT OEM exhaust, but decided to swap out the copper elbow for a more permanent solution. What I did was take a short piece of angle iron, then cut bend and weld it up to the tip of the muffler. It looks stock and changes the direction of the gas flow enough to avoid my original problems. I finally got around to posting a picture in this thread.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
