BX80 Series Announced!
   / BX80 Series Announced! #1
nikerret
Platinum Member
Kansas
Kubota BX25D-1
Kubota Introduces All New BX8 Series Subcompact Tractors | TractorByNet.com – Compact Tractor Portal
First, they follow the next number in the series, from 70 to 80, but screw up and replace he BX25 with the BX25D, then the BX25D-1, now the BX23S. What was wrong with BX26?
It looks like some really cool features will give the JD 1-series a run for the money. 80 series has a tilt steering wheel, storage compartment, removal of the FEL without getting off the tractor, and a new "four point" quick attach system. If it's the skid steer quick attach, like pictured in one of Everything Attachments' recent posts, that will destroy the competition. It also has new pins that won't leak excess grease and some other neat options.
Of course, as a ten month owner of a BX25D-1, I am wondering if I should have waited another year and a half, to get the new model. But then, I don't want a new model, I want them to get the kinks out. Perhaps, I will wear mine out, in the next year and be looking at the "upgraded" model 80 series.....:laughing:
If Kubota keeps the good things about the 70 series, I think it will be an easy choice over the JD. When I was shopping, I had them neck and neck, at the end. The JD 1-series really trumps the BX70 series in ergonomics and features. However, I found the Kubota hydraulics better, even if not as strongly rated, on paper.
   / BX80 Series Announced! #2
Oh gosh and the BX2D is one I was considering- does this mean they'll really be cutting deals on the now? Haha- wishful thinking!
   / BX80 Series Announced! #3
Sounds like a few very nice feature improvements.
   / BX80 Series Announced! #4
The loader has changed from an LA243 to an LA340 or LA344. If this is the usual KG capacity, that is a major loader lift upgrade. See photo below.
Bruce
   / BX80 Series Announced! #6
The loader has changed from an LA243 to an LA340 or LA344. If this is the usual KG capacity, that is a major loader lift upgrade. See photo below. Bruce <img src="http://www.tractorbynet.com/forums/files/kubota-buying-pricing/484026-bx80-series-announced-0816_bx23e_transport_1013-jpg"/>
It can't be kilograms unless they were BSing us before. 243 x 2.2 is only 534.6 lbs., whereas the specs say 745 lbs.
(Later: that figure may actually apply to the "500 mm forward" specs, which are listed as 518 lbs.)
   / BX80 Series Announced! #7
The improvements are welcome and overdue, time will tell if it's enough to keep up with the competition.
   / BX80 Series Announced! #8
Curious to see if this BX series will stop when the go pedal is released like all former Kubota HSTs and all other Kubotas other than BX 70 series or if it will coast on till it finally stops or the brake is engaged. If so, would that be an admission of wrong? The abrupt stop in reverse on the 50 series BXs was never acknowledged but the 60 series came out pretty quick and the issue went away in that series.
   / BX80 Series Announced! #9
Interesting to see 3 different versions of seats in the picture of the 3 models. I have never really liked the seat on my BX2360 and I had hoped that the seat from the B2301/2601 would be used in the new BX80..... but apparently it won't be.
   / BX80 Series Announced! #10
The '23S' has the same seat because of the swivel mechanism. The BX1880 has the current BX seat, the BX2380 and BX2680 do get an upgrade.
super excited for these new models. Kubota is FINALLY making really significant changes and adding some really significant features that in my mind make someone finally consider trading their old BX's on the new model.
John Deere 455G Loader (A48837)
John Deere 455G...
10' Poly Feed Trough (A50515)
10' Poly Feed...
(30) 9' Pipe Fence Posts (A50515)
(30) 9' Pipe Fence...
2015 DODGE RAM...
