Page 3 of 8 FirstFirst 123456 ... LastLast
Results 21 to 30 of 79
  1. #21
    Join Date
    Nov 2008
    Posts
    71
    Canada
    JD 3720
    Default Re: JD Front mount 59" blower
    I'll have to disagree with most posters here. I have a 3720 with the front mount 59 snowblower and use it on a 2600' curved driveway through a forested area.
    Couple issues;
    1. blower should be a foot wider for the 3720, at least with my snow conditions it would handle it and would be wider than the rear wheels.
    2. blower need some sort of shear bolt to protect the impeller. If you're lucky you won't hit anything and cause expensive damage but you shouldn't need to rely on luck with something that costs this much. Check out the links below for some people who've had these issues and some pics of the broken parts (forgot to take pics of mine on the 2 occasions I've broken the impeller mounting universal).
    http://www.tractorbynet.com/forums/j...59-blower.html
    http://www.tractorbynet.com/forums/p...-ate-rock.html
    That said I love being able to drive forward while blowing snow, wouldn't give that up (at least for my driveway). Rather than spending that much money for this blower I would evaluate all other front mount blowers the pull type blowers. I know the pull type wouldn't work well for all snow conditions but in my area I'm thinking that's what I should have gone with and leave the loader on over winter.
    Al
  2. #22
    Veteran Member Rockgod's Avatar
    Join Date
    Oct 2010
    Posts
    1,166
    CNY
    JD Cabbed 3720
    Quote Originally Posted by xkbal View Post
    Couple issues;
    Al
    I looked at both those threads and the first ones seems to have a point. However, the second one (its damage) seems to have been caused by a bolt that fell out and was used that way for at least 1 season. With that said I thank you for your input/warning.
    From the OP in second thread:
    Just to try to keep things in perspective, I need to remind myself of two things.
    1. I've used the blower for six years and have seen quite a few 4 inch rocks go flying out, or occasionally get jammed, with no breakage, other than shear bolts. I've done the 800 foot driveway many many times with no shearing of bolts at all.
    2. In this case, the bolt on the impeller shaft had somehow become lost and the key was the only thing holding the impeller on the shaft. I know this because there was wear on the blower case directly behind the impeller. In fact there was so much wear that two of the four carriage bolt heads there were worn flat and thin. I suspect that the impeller bolt was gone for at least all of this winter so far and maybe part of last winter too. When the bolt is in place, there is a good quarter inch of clearance behind the impeller.
    On the other hand, the dealer had three of the hub/U-joint pieces in stock, and when I told him how it had broken, he said "Yeah, that's how they do it."
    With luck, I can go another six years
    Tom
    JD Cabbed 3720, 3rd Function, 59" Front Mt. Blower, 66" Root Grapple, 72" Frontier RC.
  3. #23
    Join Date
    Nov 2008
    Posts
    71
    Canada
    JD 3720
    Different strokes, in 3 seasons I've broken 2 of the same castings (no bolts were missing) and as pointed out by the OP you mentioned he states that it is the failure method acknowledged by his deere dealer. My dealer stepped up and provided me the second set of parts at no charge after acknowledging that it is a design issue. Should a universal or casting not break I'm not sure what the next weak point in the system is, hopefully not something in the tractor.
    If you have a smooth driveway with no chance of something large getting stuck that's fine. In my case, both times there were broken branches blown off the trees in a storm and covered in snow. No way to see them till they had been hit.
    You can obviously go with whatever blower you want, just wish someone had warned me.
    Al
  4. #24
    Elite Member Rob-D's Avatar
    Join Date
    Oct 2006
    Posts
    3,061
    Catskills
    John Deere 3320
    Couple issues;
    Al
    Al,
    The problem with the 'U' joint breaking is very likely in the set up. When the dealer puts the blower on he should leave out the woodruff key so the bolt acts as a shear bolt. If you have a blower check to see if you have the key in. I put my blower on, not the dealer. I left out any woodruff keys on the input shaft. In fact I talked to my dealer about it and he agreed that the bolt through the U joint should shear if you get a jamb.
    I had the 47" blower on my 2720 before I got the 3320 and the set up is different, there is a specific shear bolt on the 47" blower impeller. The engineers at deere know enough to leave a weak point in the shaft. As far as people saying the bolt breaks to much I never found this, it's never broken and I have a gravel drive. In fact I have dents in my blower from stones! Make sure you don't have a key in your drive, it's simple enough to do.
    As far as the size, I've never had a problem with it and also consider this bloewr is used on several tractors, some with less power than the 3 series.
    Rob
  5. #25
    Join Date
    Oct 2006
    Posts
    3,061
    Catskills
    John Deere 3320
    Put a grade 2, 1/4-20 bolt in the shaft, it will break before the U joint. This is what I like about deere, when I had my 2320 the front drive shaft was too small, I had a problem and when I got the new shaft it was thicker. Deere fixed the battery problem too. My 3320 has a sealed battery. Battery acid eating at the front cooler is no longer an issue. If there was a problem they would have addressed it.
    Rob
  6. #26
    Join Date
    Nov 2008
    Posts
    71
    Canada
    JD 3720
    Quote Originally Posted by Rob-D View Post
    Rob
    There is a problem and they have not addressed it. Having an individual dealer suggest something contrary to the products manuals that he thinks should work is acknowledging that he believes there is an issue but it is not Deere addressing a problem. Having Deere put out a technical bulletin saying remove the key and use a grade XX bolt would be addressing it. For a several thousand dollar brand new blower I should not have to be experimenting. Every other blower that they sell (that I'm aware of) has a shear bolt for the impeller, why not this one model?
    For what it's worth I also removed the key after the first damage and managed to blow some loose snow for about 100' till I hit a drift and sheared the bolt. While I agree this will protect the universals and tractor you are not able to use the blower to it's potential. That 1/4' bolt is now the shear protection for the whole blower as that provides the power to not only the impeller but also the augers. I considered putting a stronger grade bolt in there but again we are back to whether I should have to experiment on a several thousand dollar blower that was bought brand new from the dealer and is missing a feature that the vast majority of blowers from all manufacturers have.
    I like Deere (have operated several over the years), I like the tractor, I like the dealer, but at the end of the day it's a design flaw and there should be a proper shear bolt in the system.
    As far as the size of the blower, I don't have a big problem with it. Just if I had known of the issues with the shear bolt and given the price I probably could have gotten one better suited for the size of this tractor that had been properly designed. I went with Deere as I've always had good success with products sold by them. In this case I believe I could have got a better product, for my purposes, for a similar price.
    Al
  7. #27
    Silver Member dschuffert's Avatar
    Join Date
    Jun 2012
    Posts
    104
    Beecher, IL
    John Deere 3720 Premium Cab
    I think whether you have shear protection or not depends on how old the blower is. I bought a new 59" front mount this summer for my 3520 and then moved it to my 3720. As you can see in the uploaded pictures the driveshaft does have a shear bolt on it. This is where the driveshaft connects to the shaft on the gearbox. The blower itself also comes with four extra shear bolts that are bolted to the body of the blower. The pictures that I uploaded show both.
    As a few on this thread I also believe that the John deere engineers are continually evolving a product line as they get feedback. I have not bee able to use the blower yet, but hope to this winter, then I will be able to better comment on the operation and if I experience any issues with the shear bolt setup.
    Attached Thumbnails Attached Thumbnails JD Front mount 59" blower-img_1662.jpg   JD Front mount 59" blower-img_1665.jpg   JD Front mount 59" blower-img_1663.jpg   JD Front mount 59" blower-img_1664.jpg
    2012 John Deere 3720 Premium Cab, 300CX Loader w/ 73" HD Bucket, Artillian Forks, 681 Tiller, 72D AutoConnect Mower, 59" Two-stage Snow Blower, Ballast Box, Frontier TR2058 Overseeder, Frontier SS2067B Broadcast
    Spreader, iMatch.
    1953 Ford NAA Golden Jubilee - Currently disassembled waiting for restoration.
    1947 Allis Chalmers Model B - Still running great - handed down from my Grandfather to my Father to me.
  8. #28
    Join Date
    Oct 2006
    Posts
    3,061
    Catskills
    John Deere 3320
    There is a problem and they have not addressed it. Having an individual dealer suggest something contrary to the products manuals that he thinks should work is acknowledging that he believes there is an issue but it is not deere addressing a problem. Having Deere put out a technical bulletin saying remove the key and use a grade XX bolt would be addressing it. For a several thousand dollar brand new blower I should not have to be experimenting. Every other blower that they sell (that I'm aware of) has a shear bolt for the impeller, why not this one model?
    Al
    Did you assemble your blower? Because I did and I followed the instructions AND used the parts Deere supplied. I don't remember seeing a key (I did it a few years ago) and cetainly there is no key on my shaft.
    When I approached the dealer about the second stage shearing he agreed with me that the bolt on the U joint IS a shear bolt. So I'm not modding the blower, I'm using Deere's parts and following Deere's instructions. I didn't come up with a grade 2 bolt, again, I used what Deere supplied. I seriously doubt Deere is just looking the other way when these things explode.
    I'm sure you can sell your blower for a good price , they are in demand. getting something better is a subjective assessment. You might think you're getting a better blower and find out in the end it's worse.
    Rob
  9. #29
    Join Date
    Oct 2010
    Posts
    1,166
    CNY
    JD Cabbed 3720
    Quote Originally Posted by dschuffert View Post
    Good photos dschuffert, thanks for those!
    By my count that's at least three places for shear bolts on this blower. The other two I noticed were on the main auger itself if I remember correctly. You'd think that'd be enough shear points.
  10. #30
    Join Date
    Nov 2008
    Posts
    71
    Canada
    JD 3720
    I think you'll find that what you're looking at is not a shear bolt. If the key was not installed, contrary to what the online deere parts manual shows, then you can experiment with that bolt acting as a shear bolt. I had no luck doing that. The spare shear bolts you refer to are for the auger and have been there for a long time, it's the impeller that is missing protection. If you have a look at your operator manual it will likely only reference the shear bolts on the auger. If it mentions any other shear bolts please let me know and I'll discuss it with my dealer.
    Here's the key part number from the manual and attached is the picture from the parts manual showing the driveshaft you mentioned.
    20 M84550 Shaft Key 1 (3120, 3320, 3520, 3720 CUT)
Similar Threads
  1. Price Check 54" front mount snow blower for a 2520
    By snyder_man in forum John Deere Buying/Pricing
    Last Post: 12-01-2010, 06:04 PM
  2. 59" front mount blower
    By defed in forum John Deere Owning/Operating
    Last Post: 10-26-2010, 07:17 PM
  3. 3720 59" front mount blower ?
    By xkbal in forum John Deere Owning/Operating
    Last Post: 12-12-2009, 10:52 AM
  4. bx front mount blower
    By gjock in forum Kubota Owning/Operating
    Last Post: 11-09-2009, 10:39 PM
  5. How much $$ for a front-mount blower ??
    By Skidmark25 in forum Kubota Buying/Pricing
    Last Post: 08-27-2005, 09:54 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
