TXFord8n,
First of all, I hope you have a bigger tractor in mind!
(sorry, I couldn't help myself)
About 20 years ago, I was shopping for a 10' myself. Bought a Hardee pull-type. It's a beast. It spent it's first 15 years (or so) behind a 100 hp tractor. (JD 4020, then a NH 7610S) It will basically digest anything that the tractor will run over. The only issue that I ever had was shearing off the input shaft on one of the side gearboxes, and that was my fault. I don't know if the current Hardee is the same cutter, but it could be.
Five or six years ago, I was shopping for a 7' 3ph cutter. I really wanted a Rhino TW84, but let the dealer talk me into a "great deal" on a Rhino SE7 that he still had in stock. He did give me a good price, but the SE series wasn't even close to the TW. (I believe that the Rhino models are currently referred to as the 200 and 400 series respectively) Not a bad cutter, but not heavy-duty enough to run behind a 100 hp tractor. I've bent the skirt a few times and I had to completely replace the tail-wheel assembly with a much heavier one.
Point is, buy as good of a cutter as you can reasonably afford. It will pay off in the long run. Economy cutters are for mowing grass, nothing else.
on edit:
Since you're in TX, you might want to check out the Modern Predator series. IIRC, they are built in Beaumont.
