14T baler (help ZZvyb6)
   / 14T baler (help ZZvyb6) #21
There are some pins and Woodruff keys in there that could be broken. Also, check your hitch point location and the driveshaft assembly for a possible problem there. The shaft is intended to be a constant velocity approximation. If the hitch/drawbar is too long or short or the wrong height, or the propshaft intermediate u-joints are off by 90 degrees, its gonna vibrate severly when you turn.
   / 14T baler (help ZZvyb6) #22
I have a 14T baler and the same problems and read all of this post. Has a solution been found? Are you still active on TractorByNet?
