After another viewing of the 2 pictures, Here is what I would do (assuming the shares of the plow are not worn beyond the point of no return): Remove the beaming screw (The old A-C crank) completely. Weld a piece of angle in its place, or just slightly lower than the highest hole. Put the toplink bolt through the hole where the crank is now. If this doesn't do the trick, you may actually have to go higher with that hole, by welding a set of ears with holes in them of the appropriate diameter. Get a picture of the bottom end of the plow, and I can tell you if its worth putting much effort into the project.
