Billc
- Joined
- Apr 6, 2000
- Messages
- 357
- Location
- Northwest Georgia
- Tractor
- Kubota 5400 4x4 with ROPS, canopy, 1001 loader, heavy duty quick release bucket with tooth bar, 280 Bush Hog brush cutter, 6' Bush Hog box blade, 6' Bush Hog plug aerator, 3 point hay spear, 6' Lands
MarkV, I spent some time working for Home Depot and did a lot of work on the Echo products. Each Spring we had a big gathering of the Inside Gardening folks who worked in the stores in the Atlanta area. The best treat was listening to a man we called the Echo Nazi. I can't remember his name, but he worked for Echo and was from East Germany. This man was GREAT to listen to. He loved his product. He thought the Echo 2 cycle engine was better than a Stihl or Husky. Anyway, he was also a big believe in Echo oil. It mixes at 50:1 and he said it could be used in any 2 cycle engine. He said there were only 2 good 2 cycle engine oils on the market in the U.S., the oil put out by Echo or the oil put out my Husky. He said these two oils met all sorts of standards. He said most of the other 2 cycle oils were nothing more than boat engine oils. Their ratings were based on a water cooled 2 cycle engine turning 4000 rpms at best. The Echo and Husky oils were made to run in air cooled engines at 10,000 rpms. Big difference in how they lubricate.
He also said to never let an air cooled engine idle for more than 10 seconds, there is a tremendous heat build up. It works best at full throttle, it runs much cooler at full throttle.
I have a Stihl 036 chain saw and 4 echo products (line trimmer, hedger, edger, and blower). Have never had a problem with any of them and they get used a ton.
Oh, Briggs and Straton makes a gas preservative product that will keep your gas good for 6 months. Other wise gas starts going bad after about 40 days, it turns into something similar to varnish. During the summer I don't use it, I go though the gas too fast, but heading into winter I add the preservative to the gas so it won't go bad.
Last thing, if anyone is looking for great deals on Echo products here is how to get them...and other stuff too: Home Depot has a very generous return policy. In most cases Home Depot ships the returned merchandise back to the manufacture. This in NOT the case with Echo products. Home Depot will resell the Echo returns at a big discount (about 50% if you catch them with a lot of returns on the shelf). They are not really interested in making money on the returns, rather they just want the returns out of the store! Plus the returns come with a 1 year warranty.
Can't tell you how many Echo returns I was made to take back by my bosses when there was nothing wrong with the product. Either the Echo product had been flooded (most common) or someone had bought it to use for one job and then returned it saying there was something wrong with it. Anyway, in either case one can buy a slightly used or not used at all Echo for about 50 cents on the dollar. A very good deal for a great product.
If you are now using a Weedeater, or Mac, or Ryobi, etc. try an Echo and you won't believe the difference.
And try using either Echo or Husky 2 cycle oil.
