What I was able to do so far was to check for fuel at the banjo after the filter, used the hand pump and found no bubbles at all.
Then I pulled the high pressure lines (one by one) at the injectors and turned it over, fuel ran ok no sign of air.
Then reading a couple posts I started to focus on the glow plugs. It looks like they were never working as there was no power to them even though the light goes on. This was a used tractor and it looks like the hot to the GP was ran back to a push button switch, the push button is wired to a toggle that has a fused link that goes to the aux or the ignition??????? Maybe someone can tell me why this was done this way.
So after tracing the wire, the fused link had no fuse it so no juice would pass even if I had known to hold the push switch. Any idea what size fuse this should have? I put in a 20A and tested it, now getting 12V to the GPs. Still not starting so I read how to test GPs using an ohm meter to test continuity with one contact on the GP hot and the other on a ground point on the engine...there was no continuity...my next plan is to pull the GPs out for visual inspection...is there a better way to test them? other ideas?
