NCFarmer214
- Joined
- Aug 17, 2023
- Messages
- 11
- Tractor
- 2013 Mahindra Max 28 XL HST
This is also compounded by the FEL operates but is very weak regarding lifting capacity. The rear hydraulics are fine, can lift a 800 pound mower with ease.
Tractor has been mine since 2014, It only has 104 hours on it. It was my commercial greenhouse machine and did heavy lifting at the start and close of the season. Always kept in indoors and very well maintained.
I have gone though all the obvious stuff, fluid level is good (brand new) both filters are new, no oil leaks, engine runs great. I greased it all up back in May and was using it to grade my gravel road. It got weak suddenly and I noticed the pedal got firmer feeling. I was able to limp up to shop and there it sat until I had time to look at it.
Dealership nearby doesn't troubleshoot (or know the product well) and just want to lighten my bank account of $5000 and swap out the HST. I am thinking its a hydraulic issue and this being my first HST, not sure what to try.
I have also made sure the linkages were all clean, greased, and it was all to spec per the shop manual, I did have to adjust one spring to get it to return to neutral when releasing the pedal, and I adjusted the speed control lever since the linkage was sloppy and out of spec.
Anyone else have a similar problem?
