Labrat
I have a few issues with the design of the drive line of this unit.
1. Vibration from the mid shaft. It has excessive deflection when not under load due to quick connects and no center support. If you have someone run the blower at full speed and look at the rotating shaft you can see the shaft deflection. I plan to try putting a compression spring in the shaft tube to see if keeping a constant tension on the slip joint takes out some of the vibration.
2 the front drive shaft angle when the unit is full raised or lowered is excessive causing vibration. U Joints will only tolerate a certain degree of angle before vibrating.
3. Excessive driveshaft angle due to the pitch required to get the shaft under the front axle.
4. Drive chain sprockets not correctly welded to hub causing them to run out of concentric. Will figure out what one and fix it.
As lake Ontario continues to dump snow on us every day I can’t afford to take it apart and work on it.
A guy I work with has a JD 575 with the same blower. I plan to stop by his place after work some day and see what his sounds like compared to mine.
