Okay, so every time I think I have it figured out, I start thinking again, lol.
So, I was pretty set on a Kioti CK3510 or maby LS XG3135. However, I am thinking the Kubota L Series may just have enough loader lift capacity for my needs after all. That said, the L3301 is about $3,000 more than the Kioti or LS. But, the L2501 would run about the same. I really like that the Kubota will have strong resale value, that they have a such a strong reputation for reliability and that there are several strong Kubota dealerships near my property. It's pretty much Kubota country around my parts. I also like that the L2501 would not have a regen cycle/DPF filter and, maybe this is dumb, but I like that it runs at a lower RPM.
There is just no way of knowing how each would perform on my property without having each one around for a while - which is not going to happen. I'm mostly going to be clearing brush, fence lines and trails, and maybe humping logs if I get a portable saw mill. I'd like something that can tug a shipping container around as effectively as my pickup (Toyota Tundra assisted using lumber skids below the container). The extent of rotary cutting will be related to clearing woody brush. I can't foresee more than 5 acres of grass being established on the place. The tractor will be 4WD, HST with R4 tires, whichever one I get. The property is 24 acres, sandy soils, some slopes, some flats.
For those of you who have run both 25 and 35 HP tractors, what would you say the primary differences in performance are, aside from how much or how fast you can mow grass? Also, am I crazy to be comparing an L2501 against a lesser branded 35 HP tractor? Am I just falling prey to Kubota marketing hype?
