jcmseven
Veteran Member
WH,
No need to be confrontational here. I have already complemented you earlier in the post on a nice and smart install of an exhaust in which I had interest also but never did, so please keep that in mind. My point is, honestly, and I think it is a reasonable one in this case, is that you own a modern and expensive machine. It is not a 1965-era tractor with a straight vertical exhaust . I appreciate your insight into a potential problem, but if JD has not adequately designed its OEM replacement vertical stack such that its owners do not have to worry about this occurence, the system needs to be redesigned. One should be able to choose horizontal or vertical exhaust and know that it works and is safe for the engine. I am not diminishing your concern in any way, merely that I feel badly for you (and pertinent others) that this has to be done. A drain or closing flap with the factory exhaust would be a nice option if this is an issue--from the factory and included in what you paid. Yes, you can and should have you cake and eat it too with this price of machine and I fault JD--not you--if this was not done in the design.
John M
John M
