LD1
Epic Contributor
I think I will chime in and add some more confusion.
I got my 1989 JD2555 stuck in the edge of the pond up at the church. I was pulling a 15 foot batwing mower. I hooked my newer tractor up to both of them and tried to pull it out. It is a 2013 Kubota M7040. It is rated at 3 or so horsepower less than the JD. It it 4wd, while the JD is 2wd. The Kubota would not pull the pair of them out, with both in gear. So I unhooked the mower and pulled the JD2555 out. Then I hooked a large strap I have to the rear of both tractors and ran it through a clevis on the front of the mower. With both tractors pulling, the strap started slipping towards the JD2555 side, meaning it was out pulling the Kubota, even with the Kubota in 4wd. The JD2555 is considerable heavier than the Kubota by several thousand pounds, so I think that had a lot to do with it pulling better than the Kubota. However, had I originally been pulling the batwing with the Kubota, I would probably not gotten stuck, because the front wheel drive would have allowed the front end to be steered away from the pond.
David from jax
Dont know how you have the two tractors configured ballast wise......but bare tractor JD2555 = 6200# and Kubota = 4800#.
In dry conditions, or in proper field conditions. the JD certainly has the edge. With the weight and larger tires.
But thats a perfect example about not so good conditions. You are probably right that you wouldnt have been stuck if you were pulling the batwing with the kubota from the start.
Gotta ask though......if you had the nice new kubota, why were you using the old iron for mowing?
